[Salome] Howto export Edge-Geometrie from Salome to .eMesh? |
February 20, 2019, 09:57 |
Rep Power: 14 |
Hallo,
I'm searching an workaround to get the edge geometrie of my STL-Mesh from Salome into an .eMesh file. Edit: The script "surfaceExtr..." do not work good enough. Any ideas? Thanks. |
February 20, 2019, 10:51 |
Gerhard Holzinger
Rep Power: 28 |
You can create, in Salome's GEOM module, a group of edges (i.e. your intended feature edges), and then export these edges using a very handy Python script, which was posted in the Salome forum.
The workflow: * Create geometry in Salome's GEOM geometry module * Create a group of edges in the GEOM module * Create a surface mesh in Salome's MESH module * Create a group of edges in the MESH module with Group from geometry * Select this group in the Object Browser and run this script with File -> Load Script * Export the surface mesh as an STL file This will give you your STL surface mesh, with the proper feature edges in an *.eMesh file. The thread in the Salome forum, discussing this very question |
Actuator disk model | audrich | FLUENT | 0 | September 21, 2009 07:06 |
Where's the singularity/mesh flaw? | audrich | FLUENT | 3 | August 4, 2009 01:07 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
gambit edge mesh ratio export command? | sophie | FLUENT | 0 | May 14, 2007 01:51 |
[Commercial meshers] Star mesh import problem | chris1980 | OpenFOAM Meshing & Mesh Conversion | 20 | May 8, 2006 01:07 |
