March 4, 2010, 01:40 |
sHM cannot find file
Dustin
Hey all,
I'm trying to run snappy in parallel and keep getting the error: Code:
[0] [0] [0] Cannot find file "" in directory "constant/triSurface" [0] [0] From function Time::findInstance(const fileName&, const word&, const IOobject::readOption) [0] in file db/Time/findInstance.C at line 148. [0] Thanks, Dustin |
March 8, 2010, 07:08 |
Patrick Wang
Hi Dustin,
after you run decomposePar. You have copy the triSurface folder into every constant folder of every processor folder (processor0, processor1...) Snappy should run afterwards. Patrick |
March 14, 2010, 01:01 |
Dustin
Thanks Patrick, that got it to run, but it's now failing on reconstructPar, again complaining about a missing file:
cannot open file file: caseRoot/processor0/1/polyMesh/pointProcAddressing at line 0. From function regIOobject::readStream() in file db/regIOobject/regIOobjectRead.C at line 62. FOAM exiting Thanks, Dustin |
March 15, 2010, 02:08 |
Patrick Wang
Hey,
I've never had that problem when I worked with decomposePar so I have no idea what the problem might be. It's best if you search the forum. Sorry that I couldn't be of more help. |
March 15, 2010, 04:09 |
Simon Rees
I have managed to get SHM working in parallel and can offer a couple of comments.
i. You can just make soft links to your stl file in the processor directories rather than copying it lots of times. ii. When doing the reconstruction after running SHM I found it necessary to use the -constant option to rebuild the mesh. I also found it necessary to increase the write tolerance to 10^-8 when using reconstructParMesh. |
July 14, 2010, 04:08 |
stephane sanchi
Rep Power: 18 |
hello,
I am trying to run sHM in parallel. When I run : snappyHexMesh -parallel I get the following error message [250]cfs10-sanchi /shared/sanchi/OpenFOAM/sanchi-1.7.x/pippo % snappyHexMesh -parallel 12 --> FOAM FATAL ERROR: bool Pstream::init(int& argc, char**& argv) : attempt to run parallel on 1 processor From function Pstream::init(int& argc, char**& argv) in file Pstream.C at line 73. FOAM aborting #0 Foam::error:rintStack(Foam::Ostream&) in "/shared/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt/libOpenFOAM.so" #1 Foam::error::abort() in "/shared/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt/libOpenFOAM.so" #2 Foam::Pstream::init(int&, char**&) in "/shared/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt/openmpi-1.4.1/libPstream.so" #3 Foam::argList::argList(int&, char**&, bool, bool) in "/shared/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt/libOpenFOAM.so" #4 main in "/shared/OpenFOAM/OpenFOAM-1.7.x/applications/bin/linux64GccDPOpt/snappyHexMesh" #5 __libc_start_main in "/lib64/libc.so.6" #6 _start at /usr/src/packages/BUILD/glibc-2.10.1/csu/../sysdeps/x86_64/elf/start.S:116 [cfs10:09124] *** Process received signal *** [cfs10:09124] Signal: Aborted (6) [cfs10:09124] Signal code: (-6) [cfs10:09124] [ 0] /lib64/libc.so.6 [0x2af77d069560] [cfs10:09124] [ 1] /lib64/libc.so.6(gsignal+0x35) [0x2af77d0694e5] [cfs10:09124] [ 2] /lib64/libc.so.6(abort+0x180) [0x2af77d06a9b0] [cfs10:09124] [ 3] /shared/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt/libOpenFOAM.so(_ZN4Foam5error5abortEv+0x241) [0x2af77c16f7f1] [cfs10:09124] [ 4] /shared/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt/openmpi-1.4.1/libPstream.so(_ZN4Foam7Pstream4initERiRPPc+0x2a6) [0x2af77d398b96] [cfs10:09124] [ 5] /shared/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt/libOpenFOAM.so(_ZN4Foam7argListC1ERiRPPcbb+0x2869) [0x2af77c17ec49] [cfs10:09124] [ 6] snappyHexMesh [0x40515a] [cfs10:09124] [ 7] /lib64/libc.so.6(__libc_start_main+0xfd) [0x2af77d055a7d] [cfs10:09124] [ 8] snappyHexMesh [0x404639] [cfs10:09124] *** End of error message *** Abort Any idea ? Stephane. |
July 20, 2010, 09:04 |
stephane sanchi
Rep Power: 18 |
I have found the solution reading the advices of W. Heydlauff. You don't need to copy the stl file into each processor* folder.
Hereafter isthe procedure. - run "blockMesh" a usual - decomposeMethode in decomposeParDict must be hirarcial - run "decomposePar" - run "foamJob -p -s snappyHexMesh" - afterwards run "reconstructParMesh -mergeTol 1e-06 -latestTime" (or -time 1; -time 2; ...) Works perfect for the 3 steps of sHM: castellatedMesh true; snap true; addLayers true; Stephane. |
January 9, 2019, 08:29 |
Xutong
Rep Power: 7 |
Actually it is not necessary to copy triSurface folder into every processor folder since it will read from the main constant folder anyway. I met a similar "cannot find file" problem. In my case, it was .eMesh file missing. So it was solved by just run "surfaceFeatureExtract"
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 | ordinary | OpenFOAM Installation | 19 | September 3, 2019 18:13 |
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 | tlcoons | OpenFOAM Installation | 13 | April 20, 2016 17:34 |
[swak4Foam] Error bulding swak4Foam | sfigato | OpenFOAM Community Contributions | 18 | August 22, 2013 12:41 |
friction forces icoFoam | ofslcm | OpenFOAM | 3 | April 7, 2012 10:57 |
ParaView Compilation | jakaranda | OpenFOAM Installation | 3 | October 27, 2008 11:46 |
