[snappyHexMesh] stl geometry trouble
Old   December 1, 2010, 10:25
Default stl geometry trouble
vaina74 is on a distinguished road
Hi everybody.
I'm testing snappyHexMesh - I used other meshing software - but I have a problem with the stl geometry. I obtain:
Shell ***.stl does not support testing for inside
Probably it is not closed.
What's the problem? How can I fix it? I attach my files.
Thanks for your attention.
vaina74 is offline   Reply With Quote
Old   December 7, 2010, 05:11
colinB is on a distinguished road
Hi
simple problem:
the geometry is not closed you provided and so sHM can not define the inside for the refinement parameter. so you need to close the end of your geometry or change refinement to distance
regards
Colin
colinB is offline   Reply With Quote
[snappyHexMesh] SHM does not follow STL geometry well Illmatic OpenFOAM Meshing & Mesh Conversion 7 July 23, 2016 11:07
[Workbench] Meshing and export mesh from STL geometry alerfreire ANSYS Meshing & Geometry 0 March 26, 2013 09:25
[ICEM] STL Geometry in ICEM asal ANSYS Meshing & Geometry 3 February 5, 2013 09:44
fan with geometry stl Hitomi OpenFOAM 1 August 18, 2011 11:27
vitual _ real deneb FLUENT 3 January 22, 2007 04:31
