[Other] a question about inner sampling faces
Old   November 8, 2011, 11:05
Default a question about inner sampling faces
chenkai
xck1986 is on a distinguished road
Hi everyone,
I am now simulating two phase flow with Lagrange particle tracking in OpenFOAM.
My domain is a simple rectangular duct. In order to compare the numerical particle properties with experiment data, I need to define a inner patch in my domain, which is parallel to the patch: Inlet and outlet, to sample the particle data.
I have try with createBaffles to convert a faceSet to a patch. But I failed, because I am not familiar with these commands.
Does anyone has idea, how to create a inner sampling faces, which is only used to sample the data of the particles, who passes through it.
thanks a lot in advance
xck1986 is offline   Reply With Quote
[Other] Can't Shake Erros: patch type 'patch' not constraint type 'empty' BrendaEM OpenFOAM Meshing & Mesh Conversion 12 April 3, 2022 18:32
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
Compressor Simulation using rhoPimpleDyMFoam Jetfire OpenFOAM Running, Solving & CFD 107 December 9, 2014 13:38
createPatch Segmentation Fault (CORE DUMPED) sam.ho OpenFOAM Pre-Processing 2 April 21, 2014 02:01
[ICEM] Export ICEM mesh to Gambit / Fluent romekr ANSYS Meshing & Geometry 1 November 26, 2011 12:11
