[snappyHexMesh] Snappy. Mesh region between 2 concentric stls |
May 16, 2014, 09:46 |
M. Montero
Rep Power: 17 |
Hi all,
I am trying to mesh the region between 2 stls. Originally there were 2 meshes. The bigger one in which some cells were removed using subsetMesh and and internal Mesh. The objective is to create new grid in the region between both meshes and so, to obtain a unique mesh but keeping the original ones. After snappy, the next step would be to merge all meshes and stich the meshes to delete all internal faces. I have 2 stls. The geometries were obtained using foamToSurface+surfaceSplitByPatch. Could you give me some guidance about how to proceed with snappy or if the procedure is not valid? Best Regards Marcelino Last edited by be_inspired; May 18, 2014 at 19:03. |
Can't get chtMultiRegionSimpleFoam to working. | shiromaniac | OpenFOAM Running, Solving & CFD | 11 | October 18, 2021 08:40 |
[snappyHexMesh] Help with Snappy: no layers growing | GianF | OpenFOAM Meshing & Mesh Conversion | 2 | September 23, 2020 08:26 |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
Read data for mesh REGION | AlexRonto | FLUENT | 0 | July 26, 2017 15:43 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 09:38 |
