[Technical] hex mesh
Old   March 16, 2010, 07:10
Default hex mesh
vaina74 is on a distinguished road
I have two questions, I think they are two questions connected to each other.
1. My aim is to study the performance of a 'hydro' foil with OpenFOAM (and later on a propeller) and I'm going to create the computational domain with Salome. I'm an absolute beginner, so I proceed step by step. I made a simple model: a parallelepiped cutted by a cylinder; then partitioned by two planes (look at the picture). I'm trying to build a hexahedral mesh but i only obtain the message 'Unexpected geometry. Wrong number of wires' or similar. Can you help me, please?
2. I tried to 'translate' in GUI language the TUI tutorial about the hex mesh for a cylindric domain (on Salome). I almost made the grade (sic!) but I have some problems about 1D discretization. I can't set a different number of segments for each 'dimension', as in the tutorial. Maybe I'm wrong with the 'side group' (are face_a and face_b the bases of the cylinder?). My parameters are
[whole object]
hypotheses: nb Segments = 1;
algo: regular_1D; quadrangle_2D; hexa_3D;
[face a, face b]
hypotheses: nb Segments 1 = na, nb;
[side group]
hypotheses: nb Segments =nl;
vaina74 is offline   Reply With Quote
Old   March 19, 2010, 02:21
linnemann's Avatar
Niels Nielsen
linnemann will become famous soon enough
To create a hex mesh in Salome you need each face to consist of 4 edges. The meshing will fail as you see if you have more than 4.
Create you geometry with 4 faces like so, and it should work.
Linnemann
PS. I do not do personal support, so please post in the forums.
linnemann is offline   Reply With Quote
Old   March 19, 2010, 05:23
Thanks for your reply. In the meanwhile, I went on with my exercises and tries (also the meshing tutorials), so I understood the 4 edges requirement.
Old   February 5, 2013, 18:48
Abbas Rahimi
AbbasRahimi is on a distinguished road
Hello
I faced to the same problem but I cant figure out how I can push each face to just have 4 edges! Could you please provide me some leads???
Thanks
AbbasRahimi is offline   Reply With Quote
[blockMesh] --> FOAM FATAL ERROR: Trying to specify a boundary face A.A. OpenFOAM Meshing & Mesh Conversion 41 June 26, 2020 07:06
[snappyHexMesh] Snappy Hex Mesh External Domain willindsey OpenFOAM Meshing & Mesh Conversion 2 June 9, 2017 22:03
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 06:21
[blockMesh] apparently the mesh doesn't want to be created in one direction Maxime Thomas OpenFOAM Meshing & Mesh Conversion 1 August 18, 2012 06:05
