[mesh manipulation] Unstructured tetrahedral mesh Refinement using REFINEMESH DICT UTILITY.???? POSSIBLE?
Like Tree2Likes
  • 2 Post By saddy
Old   July 11, 2017, 14:15
Default Unstructured tetrahedral mesh Refinement using REFINEMESH DICT UTILITY.???? POSSIBLE?
sandy
saddy is on a distinguished road
Hey foamers
i am working on a problem with a cylinder with tetrahedral mesh created in gambit. pic is attached below.
i want to know whether refinement is possible near the wall region, say a circular patch from the walls, can this be done using Refinemesh -dict utility???
plzz helppp
saddy is offline   Reply With Quote
Old   July 11, 2017, 17:41
sandy
oh hell yeah its possible just did it.....
Old   July 11, 2017, 17:47
Thomas
Tomatenbart is on a distinguished road
Would be nice if you could share it with us. So if someone comes to the same problem, he/she knows what to do.
Sent from my iPhone using CFD Online Forum mobile app
Tomatenbart is offline   Reply With Quote
Old   July 12, 2017, 05:02
Lightbulb
sandy
actually i have a cylinder
i have to refine the mesh along the circumference
so i created annular to cell in toposetdict
and hybrid structured/unstructured mesh in gambit
then i used use hextopology to cut the cells in all three directions and refined from 0.1 milion cells to 2million cells using refinemesh utility
this is my refinemesh dict
| \\ / O peration | Version: plus |
| \\ / A nd | Web: www.OpenFOAM.com |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object refineMeshDict;
set c0;
coordinateSystem global;
globalCoeffs
tan1 (1 0 0);
tan2 (0 1 0);
normal (0 0 1);
directions ( tan1 tan2 normal );
useHexTopology yes;
geometricCut no;
writeMesh no;
this is my toposetdict
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object topoSetDict.1;
actions
name c0;
type cellSet;
action new;
source cylinderAnnulusToCell;
sourceInfo
p1 (0 0 0);
outerRadius 0.012;
p2 (0 0 0.144);
innerRadius 0.009;
first load your gambit mesh to openfoam using gambittooam3d -scae 0.001 etc..just see the command guys
next run this commands[allrun file ] to read toposetdict and refinemesh
#!/bin/sh
cd ${0%/*} || exit 1 # Run from this directory
# Source tutorial run functions
. $WM_PROJECT_DIR/bin/tools/RunFunctions
refineMeshByCellSet()
while [ $# -ge 1 ]
do
if [ ! -e log.refineMesh.$1 ]
then
echo "Creating cell set for primary zone - $1"
cp system/topoSetDict.$1 system/topoSetDict
topoSet > log.topoSet.$1 2>&1
echo "Refining primary zone - $1"
refineMesh -dict system/refineMeshDict -overwrite \
> log.refineMesh.$1 2>&1
fi
shift
done
//restore0Dir
//runApplication blockMesh
refineMeshByCellSet 1 2 3 4 [// 1,2,3,4 depend on no times you want to refine]
//#echo "mapping fields from 2D throttle case"
//#runApplication mapFields ../throttle -sourceTime latestTime
//runApplication decomposePar
//runParallel $(getApplication)
//runApplication reconstructPar
i have attached the results
this refinement is for all 3 directions
guin and Tomatenbart like this.
Old   February 1, 2019, 05:58
samuel
samuel_rff is on a distinguished road
You don't solve the post.
How use refineMesh with tetra?
samuel_rff is offline   Reply With Quote
refinemesh utility
y+ = 1 boundary layer mesh with snappyHexMesh Arzed23 OpenFOAM Running, Solving & CFD 6 November 23, 2022 15:15
[snappyHexMesh] SnappyHexMesh running killed! Mark JIN OpenFOAM Meshing & Mesh Conversion 7 June 14, 2022 01:37
[snappyHexMesh] problems generating clean mesh Christian_tt OpenFOAM Meshing & Mesh Conversion 2 June 20, 2019 05:39
[snappyHexMesh] snappyHexMesh aborting Tobi OpenFOAM Meshing & Mesh Conversion 0 November 10, 2010 03:23
