[mesh manipulation] MapConsistentVolField.H and IOobjectList
Old   June 5, 2018, 04:17
Default MapConsistentVolField.H and IOobjectList
krishna kant
kk415 is on a distinguished road
Hi I am new in C++ so I dont know the structure database used in openFoam. The problem I am facing is typically a programming language problem. I dont know the correct command for my purpose. Any help will be deeply appreciated.
\\ / F ield | OpenFOAM: The Open Source CFD Toolbox
\\ / O peration |
\\ / A nd | Copyright (C) 2011-2015 OpenFOAM Foundation
\\/ M anipulation |
License
This file is part of OpenFOAM.
OpenFOAM is free software: you can redistribute it and/or modify it
under the terms of the GNU General Public License as published by
the Free Software Foundation, either version 3 of the License, or
(at your option) any later version.
OpenFOAM is distributed in the hope that it will be useful, but WITHOUT
ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License
for more details.
You should have received a copy of the GNU General Public License
along with OpenFOAM. If not, see <http://www.gnu.org/licenses/>.
#ifndef MapConsistentVolFields_H
#define MapConsistentVolFields_H
#include "GeometricField.H"
#include "meshToMesh0.H"
#include "IOobjectList.H"
namespace Foam
template<class Type, class CombineOp>
void MapConsistentVolFields
const IOobjectList& objects,
const meshToMesh0& meshToMesh0Interp,
const meshToMesh0:rder& mapOrder,
const CombineOp& cop
const fvMesh& meshSource = meshToMesh0Interp.fromMesh();
const fvMesh& meshTarget = meshToMesh0Interp.toMesh();
word fieldClassName
GeometricField<Type, fvPatchField, volMesh>::typeName
IOobjectList fields = objects.lookupClass(fieldClassName);
Info<< " interpolating " << fields.lookup(name)
<< endl;
forAllIter(IOobjectList, fields, fieldIter)
Info<< " interpolating " << fieldIter()->name()
<< endl;
// Read field
GeometricField<Type, fvPatchField, volMesh> fieldSource
*fieldIter(),
meshSource
IOobject fieldTargetIOobject
fieldIter()->name(),
meshTarget.time().timeName(),
meshTarget,
IOobject::MUST_READ,
IOobject::AUTO_WRITE
if (fieldTargetIOobject.headerOk())
// Read fieldTarget
GeometricField<Type, fvPatchField, volMesh> fieldTarget
fieldTargetIOobject,
meshTarget
// Interpolate field
meshToMesh0Interp.interpolate
fieldTarget,
fieldSource,
mapOrder,
cop
// Write field
fieldTarget.write();
else
fieldTargetIOobject.readOpt() = IOobject::NO_READ;
fieldSource,
mapOrder,
cop
// Write field
} // End namespace Foam
#endif
The above is a code for MapConsistentVolField.H, I have issue with the line highlighted/underlined. In that line the "fields" is suppose to take list of all the variables like P,T for classtype volScalar. How can I check that list of variables stored in fields.
I am trying commands like fields.lookup(name) to know the name of the variables that is in the list of fields. It is showing error "MapConsistentVolFields.H:56:52: error: no matching function for call to ‘Foam::IOobjectList::lookup(<unresolved overloaded function type>)’". what is the correct command for this purpose?
kk415 is offline   Reply With Quote
[OpenFOAM] Acquiring scalar names tj22 ParaView 4 May 17, 2006 13:01
