[snappyHexMesh] Problem in layer addition at complex/bend shapes |
November 6, 2015, 09:48 |
Vineet Bhola
Rep Power: 10 |
Hi guys,
I am trying to add boundary layers for my mesh. It works fine for smoother or simpler places bu where the surface is a bit complex OR has been snapped into Polyhedral cells, the layers are not added. I also tried using RefineWalllayer and saw similar mesh Quality. Does anyone knwo which Parameter do I Need to Change in my snappyhexmeshdict? Thanks Vineet |
[snappyHexMesh] SnappyHexMesh - no layer added | bejbro | OpenFOAM Meshing & Mesh Conversion | 5 | February 1, 2020 20:05 |
Topology changes - problem when adding a layer for the second time | mike.franky | OpenFOAM Running, Solving & CFD | 0 | September 30, 2017 08:26 |
[snappyHexMesh] Problem with snappyHexMesh | samiam1000 | OpenFOAM Meshing & Mesh Conversion | 2 | December 13, 2012 08:41 |
[snappyHexMesh] Boundary layer addition at corners | bouclette | OpenFOAM Meshing & Mesh Conversion | 2 | July 26, 2011 05:31 |
[snappyHexMesh] snappy hangs while layer generation | bastil | OpenFOAM Meshing & Mesh Conversion | 3 | October 29, 2010 07:19 |
