[snappyHexMesh] snappy hex mesh error
Old   October 9, 2009, 03:29
Thumbs down snappy hex mesh error
CFT
CFT
CFT is on a distinguished road
Dear all
I was running the motorbike snappyhexmesh example. After creating the blockmesh using the blockmesh command. I run snappyhexmesh but get the following error
Surface refinement iteration 7
Marked for refinement due to surface intersection : 19 cells.
#0 Foam::error:rintStack(Foam::Ostream&) in "/home/steven/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/home/steven/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so"
#2 Uninterpreted: [0xffffe400]
#3 Foam::meshRefinement::markSurfaceCurvatureRefineme nt(double, int, Foam::List<int> const&, Foam::Field<Foam::Vector<double> > const&, Foam::List<int>&, int&) const in "/home/steven/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libautoMesh.so"
#4 Foam::meshRefinement::refineCandidates(Foam::Vecto r<double> const&, double, Foam::PtrList<Foam::featureEdgeMesh> const&, Foam::List<int> const&, bool, bool, bool, bool, int, int) const in "/home/steven/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libautoMesh.so"
#5 Foam::autoRefineDriver::surfaceOnlyRefine(Foam::re finementParameters const&, int) in "/home/steven/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libautoMesh.so"
#6 Foam::autoRefineDriver::doRefine(Foam::dictionary const&, Foam::refinementParameters const&, bool) in "/home/steven/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libautoMesh.so"
#7 main in "/home/steven/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/snappyHexMesh"
#8 __libc_start_main in "/lib/libc.so.6"
#9 Foam::regIOobject::writeObject(Foam::IOstream::str eamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const in "/home/steven/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/snappyHexMesh"
Floating point exception
Does anyone know what is wrong ?
thanks
cft
CFT is offline   Reply With Quote
Old   October 9, 2009, 07:32
bigphil's Avatar
Philip Cardiff
bigphil will become famous soon enoughbigphil will become famous soon enough
CFT,
Which version of OpenFOAM are you using?
I am using 1.5-dev and the motorBike tutorial runs for me by just blockMesh followed by snappyHexMesh.
I have attached what my snappyHexMeshDict looks like, I assume yours should be the same and if not could be the cause of the problem.
Hope it helps,
Philip
bigphil is offline   Reply With Quote
Building OpenFOAM1.7.0 from source ata OpenFOAM Installation 46 March 6, 2022 13:21
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
Compiling dynamicTopoFvMesh for OpenFOAM 2.1.x Saxwax OpenFOAM Installation 25 November 29, 2013 05:34
[blockMesh] apparently the mesh doesn't want to be created in one direction Maxime Thomas OpenFOAM Meshing & Mesh Conversion 1 August 18, 2012 06:05
CheckMeshbs errors ivanyao OpenFOAM Running, Solving & CFD 2 March 11, 2009 02:34
