[Other] Getting the cells next to a patch
Like Tree15Likes
  • 1 Post By arkangel
  • 10 Post By hjasak
  • 3 Post By nygbook
  • 1 Post By nygbook
Old   December 8, 2010, 09:05
Default Getting the cells next to a patch
O R
arkangel is on a distinguished road
Dear Foamers,
I want to get the indexes of the cells right next to a patch. In other words, I want to access the owner index of a face that conforms a patch
something like this
foreach (patchList , patchI){
    foreach (patchList[patchI].faces(), facesI){
        mesh.C[patchList[patchI].faces[facesI].owner] =val;
or maybe you have a better idea of how can I do it
thanks !!
mm.abdollahzadeh likes this.
arkangel is offline   Reply With Quote
Old   December 20, 2010, 12:43
Hrvoje Jasak
Do patch.faceCells()
That will give you cell indices for cells next to patch faces.
Enjoy,
Hrv
Hrvoje Jasak
Old   January 25, 2011, 11:33
O R
Thanks a lot Hrv!
Now I want to access the face values of a boundary patch in a specific scalarField/vectorField using these indexes.
I mean, let says that
forAll ( patch.faceCells(),cellI) gives me indexes cellI=1 2 ....
then cell[1] has a face on this patch whose b value is -1.0, where b is an scalar field
I want to recover this -1.0.
I hope I was clear enough
Regards
Old   April 13, 2011, 21:21
NieYongguang
nygbook is on a distinguished road
I suggest you read the code in wallViscosity
HTML Code:
  const fvPatchList& patches = mesh.boundary();
    forAll(patches, patchi)
        const fvPatch& currPatch = patches[patchi];
        if (isType<wallFvPatch>(currPatch))
            scalarField& nutw = nutb.boundaryField()[patchi];
            forAll(currPatch, facei)
                label faceCelli = currPatch.faceCells()[facei];
                // calculate yPlus
                scalar yPlus =
                    Cmu25*y[patchi][facei]
                   *::sqrt(k[faceCelli])
                   /nub_;
                if (yPlus > 11.6)
                    nutw[facei] =
                        yPlus*nub_*kappa_
                       /::log(E_*yPlus)
                      - nub_;
                else
                    nutw[facei] = 0.0;
where k[faceCelli] is the turbulent kinetic in cell close to wall. However, I have another question. What is y[patchi][facei] and nutw[facei]? According to wall function theory, y[patchi][facei] and nutw[facei] should be distance between center of cell and wall and viscosity in cell close to wall. why cann't write nutw[faceCelli]
sushant, mm.abdollahzadeh and tiam like this.
nygbook is offline   Reply With Quote
Old   April 13, 2011, 21:34
NieYongguang
another question
what different is betweent U.boundaryField( )[patchi].patchInternalField( ) and U[faceCelli]
Old   April 23, 2012, 08:10
Darío López
darlopez is on a distinguished road
Hi everybody.
I try to program the Simpson's rule in order to obtain the pressure force on a patch. To do it I should obtain the value of the pressure in all cells next to the patch. I have programed:
forAll(forcePatches, patchi)
const fvPatch& curPatch = forcePatches[patchi];
label forcePatchID = mesh.boundaryMesh().findPatchID(forcePatches[patchi]);
if (isType<wallFvPatch>(forcePatches[patchi]))
scalarField& pp = p.boundaryField()[patchi];
forAll(forcePatches[patchi], facei)
label faceCelli = curPatch.faceCells()[facei];
P[faceCelli]=pp[faceCelli]; // I save the values of pressure in vector P
// Now, Simpson's rule:
int i = 1;
for(int i = 1; i <= 374; i++) // I have 750 cells on each patch
A = A + 2 * P[2*i]*0.02*0.02; // where 0.02*0.02 is the area of the face of each cell
int j = 2;
for(int j = 2; j <= 375; j++)
B = B + 4 * P[2*j-1]*0.02*0.02;
a0 = P[1];
an = P[750];
scalar PressForce = 0.02/3*(a0 + A + B + an);
vector patchPressForce = PressForce * gSum(mesh.Sf().boundaryField()[forcePatchID])/gSum(mesh.magSf().boundaryField()[forcePatchID]);
// Multiply the resulting force by density to account for normalisation in
// incompressible solvers, and get component in direction of motion
scalar totPatchPressForce = (patchPressForce
* mediumRho.value()
) & aVector;
Info << "Area of patch " << forcePatches[patchi] << " [m^2] = "
<< gSum(mesh.magSf().boundaryField()[forcePatchID]) << endl;
Info << "Pressure force on patch " << forcePatches[patchi] << " [N] = " << totPatchPressForce << endl;
totPressureForce += totPatchPressForce;
Info << "Total Pressure Force along motion vector [N] = " << totPressureForce << endl;
But this loop does not work. Any ideas?? Where is the problem??
Thanks a lot.
Darío
darlopez is offline   Reply With Quote
cellZone not taking all the cells inside rahulksoni OpenFOAM Running, Solving & CFD 6 January 25, 2019 00:11
[snappyHexMesh] SHM Layer Addition Phase dickcruz OpenFOAM Meshing & Mesh Conversion 4 November 1, 2018 07:05
[snappyHexMesh] sHM layer process keeps getting killed MBttR OpenFOAM Meshing & Mesh Conversion 4 August 15, 2016 03:21
Problem with cyclic boundaries in Openfoam 1.5 fs82 OpenFOAM 36 January 7, 2015 00:31
Cyclic Boundary Condition Luiz Eduardo Bittencourt Sampaio (Sampaio) OpenFOAM Running, Solving & CFD 36 July 2, 2012 12:23
