[snappyHexMesh] .STL: non-closed manifold surface
Like Tree9Likes
Old   October 28, 2013, 05:05
phil
gelbebanane is on a distinguished road
Hey,
i've got similar problems to giulio. My biggest problem is, that my stl file is not closed and i get pretty bad snapping at the edges.
I tried to repair/clean my stl with Meshlab but without big efforts.
Perhaps you could have a look at my stl. The geometry will be used as a pipe streaming through the big patches.
kanal_original.txt
Greetings
gelbebanane is offline   Reply With Quote
Old   November 2, 2013, 13:39
Retired Super Moderator
Bruno Santos
Greetings Phil,
I had a look into your file and here's what I got:
  1. surfaceCheck indicates that there are 8 unconnected regions:
    surfaceCheck kanal_original.stl
  2. The reason for this is shown in the attached image, namely that not all vertices are connected to other vertices.
Therefore, it's as good as there are surfaces floating surfaces, when it should be a solid.
As for fixing it... in Meshlab, you can use from the menu "Filters -> Remeshing, Simplification and reconstruction -> Delaunay Triangulation". I wont be a perfect triangulation, but at least it fixes the problem
Best regards,
Bruno
Old   February 27, 2015, 02:37
pizzaspinate is on a distinguished road
may I also ask sth regarding surfaceSubset?
I have copied the surfaceSubsetDict and try to run it for my case but I get the error
Istream not OK for reading dictionary
Any ideas how I can fix this?
Thank you very much in advance for your help!!!
pizzaspinate is offline   Reply With Quote
Old   February 27, 2015, 15:19
Bruno Santos
Originally Posted by pizzaspinate View Post
Greetings pizzaspinate,
I think I saw a similar thread of yours on this topic, where you then stated that you managed to fix it. But now I see that you asked this here as well.
Therefore, if you've managed to solve this problem, then please indicate how you fixed it.
If you haven't solved this problem, then please provide more details (namely, if you did any modifications to the dictionary file "surfaceSubsetDict"), since that error message can occur in a lot of situations.
Best regards,
Bruno
Old   March 3, 2015, 04:41
Hi Bruno,
yeah I posted it twice because in my experience you don't get much responses when you reply in old threads. Sorry for that.
Yes I managed to fix it. I had to enter the command:
surfaceSubset surfaceSubsetDict UCAV.stl UCAV_prob.stl
in constant/trisurface to avoid the error.
wyldckat likes this.
Old   April 15, 2016, 06:41
gned
gned is on a distinguished road
dear wyldKat,
very quickly : i need to fix some .stl files to then use in OF. I have blender.
How to just add a lower cap (as inlet) to this stl https://www.dropbox.com/s/hzgq9l0e72...perta.stl?dl=0 (which is the bottom of my object), so to have one single .stl file which passes the surfaceCheck ? Could you gently post it ?
This old link you suggested here http://engits.eu/wiki/index.php/Tuto...ing_Geometries where is now?
thanks a lot, have a nice day,
i
gned is offline   Reply With Quote
Old   April 15, 2016, 18:00
Bruno Santos
How to just add a lower cap (as inlet) to this stl [...]
Quick answer: I've updated the link on the post you mentioned and the new link is this one: https://github.com/enGits/engrid/wik...and-enGrid-1.2
And sorry, but I don't have the time needed to fix that STL file, specially because I barely know how to use Blender
Old   April 24, 2016, 07:01
Bruno Santos
Quoting the PM you sent me:
Hi wyldkat,
thank you for the updated link, it has been very useful.
Using different tools, as Blender and Freecad, and operations of cutting/extrusion/filling I got this final stl
https://www.dropbox.com/s/z5tyrv4y2n...y_018.stl?dl=0
It's clean but when you surfaceCheck it, still it splits the external case and the inside poppet in two .obj files (I think just for a different not conform triangulation of the two objects at their border more than for reasons of really non- stitching edges/gaps there).
So which tool or OF surface* utility you usually recommend to obtain a really perfect stl file, still divided in different solids as this one, but which is one unique watertight stl file, before sHM it ?
thanks a lot,
i
Sorry, like I wrote in my previous post, I don't have time to look into this.
OpenFOAM itself doesn't have utilities that will solve these problems automatically.
You can try and use this STL and see if snappyHexMesh can still use it, regardless of the errors.
Old   April 28, 2016, 08:53
Thazin
Txinsoulkg is on a distinguished road
hi, I've problems using surfaceCheck. And I already used Meshlab and Admesh but it isnot completely removed that problems.
What should I do?
Txinsoulkg is offline   Reply With Quote
Old   May 1, 2016, 19:04
Bruno Santos
Quick answer: http://www.cfd-online.com/Forums/ope...sh-salome.html
Old   October 11, 2016, 10:33
Default 2 blocks to merge
  #31
gned
dear wildcat,
I have 2 simple .stl files representing 2 plates I need to merge together (see pic1), so I proceed doing :
> surfaceAdd solid_1.stl solid_2.stl 2solids.stl
Then I wanted to exploit the problemFaces given in output by
> surfaceCheck 2solids.stl
to eliminate them through
> surfaceSubset surfaceSubsetDict 2solids.stl 2solids_after.stl
in order to have no duplicated internal faces at the merging of the plates.
But actually the problemFaces that OF catches result to be strangely the lateral ones to the plates (see pic) and not the internal faces as expected.
So why this and how I can then obtain a unique .stl which passes the surfaceCheck ?
Old   November 23, 2016, 07:31
Joost
JD1995 is on a distinguished road
Hello everybody,
to become familiar with OpenFOAM I am trying to run an OpenFOAM case, which is modified from the motorBike case. I tried to replace the motorBike with a sphere that has a diameter of 1 [m]. This sphere is drawn in SolidWorks and compressed to a .stl.gz file. To minimalize the chance of mistakes I have given this sphere the name motorBike.stl, I am using SHM to mesh the sphere, and the blockMesh of the original motorBike case. The SHMDict and surfaceFeatureExtractDict are attached.
The problem I am facing is that the mesh around the sphere isn't visible in paraFoam, or isn't even made at all during the SHM command. I have tried to make the sphere smaller, and also tried to use RhinoCeros to draw the sphere, without any succes. I also tried to change settings in the SurfaceFeatureExtractDict, also without improvement.
My question is if there is anybody that has a suggestion or have been facing a similar problem?
Many thanks in advance!
Best Regards,
Joost
JD1995 is offline   Reply With Quote
Old   November 25, 2016, 03:15
Joost
Hello again,
I have found my problem..
My sphere has a diameter of 1 [m], so does my mesh have. The centre of the sphere was placed exactly on the centre of 1 mesh cell, so the sphere didn't cut through any cellborder, and for that reason the sphere wasn't visible at all.
My bad! Hope this answer will help people with the same problem.
Regards,
Joost
[snappyHexMesh] how to fix not closed surface and unconnected parts in stl file meithid OpenFOAM Meshing & Mesh Conversion 2 August 22, 2020 21:09
source not closed and manifold error while performing boolean(subtract) operation rockydongre STAR-CCM+ 3 May 24, 2019 01:38
[snappyHexMesh] Bad/jagged mesh around intersection of two .stl bodies MBttR OpenFOAM Meshing & Mesh Conversion 7 October 14, 2016 03:57
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
[snappyHexMesh] Layers not closed around air foil of vertical turbine carstenf OpenFOAM Meshing & Mesh Conversion 2 March 9, 2014 20:16
