[Other] Meshing for Streamlined Objects, i.e. aerofoils, bullets, rockets, ...
Old   June 29, 2012, 08:15
Default Meshing for Streamlined Objects, i.e. aerofoils, bullets, rockets, ...
aerospain
aerospain is on a distinguished road
Send a message via Skype™ to aerospain
Hi all!
I would like to know if there is a way of generating a mesh for this kind of objects with blockMesh or snappy, directly, which gives the user control on orthogonality at wall, besides clustering at leading and trailing edges (or base).
Some colleagues of mine are validating some commercial softwares and would like to take the step into OpenFOAM, but are a bit "scared" on the meshing process.
I know we could always go to OpenSource meshers but, besides programming our own generator, we would like to give a go to OpenFOAM tools.
I've taken a look at the airfoil2D tutorial, but the mesh has been generated and there is no blockMeshDict.
Any help or pointing towards forum entries will be welcomed.
Thanks!
aerospain is offline   Reply With Quote
Old   July 4, 2012, 07:38
colinB is on a distinguished road
you might want to have a look here:
http://www.cfd-online.com/Forums/ope...-naca0012.html
colinB is offline   Reply With Quote
Old   July 4, 2012, 07:52
aerospain
Thanks Colin!
I see you were quite active in that post. From the last pictures shown by that guy you helped, I am still wondering if I can get orthogonality around aerofoil without "playing" with point distribution between wall and inlet "arc". I assume that guy was talking about a C-H mesh for 2D aerofoils.
I'll give it a go and let you know.
cheers!
[Gmsh] Vertex numbering is dense KateEisenhower OpenFOAM Meshing & Mesh Conversion 7 August 3, 2015 10:49
[snappyHexMesh] snappyHexMesh meshing two close objects gap Bollonga OpenFOAM Meshing & Mesh Conversion 1 August 19, 2014 06:37
[Other] Meshing Techniques for Heat Transfer with Cube Shaped Objects cbritan OpenFOAM Meshing & Mesh Conversion 4 March 2, 2011 01:12
Which trailing edge is correct for meshing of aerofoils for CFX LSC CFX 0 May 10, 2009 12:45
Meshing 2 separate objects david Main CFD Forum 2 March 12, 2007 07:37
