[Other] making a sphere in openfoam!!! please help me
Old   July 24, 2012, 10:13
Default making a sphere in openfoam!!! please help me
adambarfi's Avatar
Mostafa Mahmoudi
adambarfi is on a distinguished road
Send a message via Yahoo to adambarfi Send a message via Skype™ to adambarfi
hi everybody,
I want to analyze the convection in a sphere. I create my meshes in gambit and use the fluent3DMeshToFoam to convert it to openfoam file, but the below error appear:
PHP Code:
Build  2.0.1-51f1de99a4bc
Exec
fluent3DMeshToFoam 01.msh
Date
Jul 24 2012
Time
18:37:42
Host
mostafa-desktop
PID
3522
Case   : /home/mostafa/mantleconvection
nProcs
1
sigFpe
Enabling floating point exception trapping (FOAM_SIGFPE).
fileModificationChecking Monitoring run-time modified files using timeStampMaster
allowSystemOperations
Disallowing user-supplied system call operations
Create time
--> FOAM FATAL IO ERROR
cannot find file
file
: /home/mostafa/mantleconvection/system/controlDict at line 0.
    From
function regIOobject::readStream()
in file db/regIOobject/regIOobjectRead.C at line 73.
FOAM exiting
what should I do?
adambarfi is offline   Reply With Quote
Old   July 25, 2012, 07:21
adambarfi's Avatar
Mostafa Mahmoudi
Is here anyone can help me?!!!please.
OK, a new question: How can I model a sphere in OpenFoam?
Old   July 25, 2012, 08:10
Assistant Moderator
Bernhard Gschaider
Originally Posted by adambarfi View Post
hi everybody,
PHP Code:
Exec
Date
Jul 24 2012
Time
18:37:42
Host
mostafa-desktop
PID
3522
nProcs
1
sigFpe
Create time
cannot find file
file
    From
FOAM exiting
what should I do?
OF doesn't find the controlDict. Either you're in the wrong directory or there is no controlDict
Old   July 25, 2012, 12:47
adambarfi's Avatar
Mostafa Mahmoudi
Thank you Bernhard,
I create files and run it again, all things was alright except the blockMeshDict file. It remains without change. If I want to fill it, I don't know what is the number of vertexes and which vertexes are connected to each other!!!!! I have more than 200000 nodes.
What should I do? please.
Old   July 25, 2012, 13:23
Assistant Moderator
Bernhard Gschaider
Thank you Bernhard,
I don't understand your problem. If you import a fluent-mesh then you don't need a blockMeshDict. After the import you should have a valid mesh in constant/polyMesh
Old   July 25, 2012, 13:26
adambarfi's Avatar
Mostafa Mahmoudi
this file is initially empty, after converting and running blockMesh it still remain empty?!?!?
is it your mean that blockMeshDict isn't necessary?
Old   July 25, 2012, 18:17
Assistant Moderator
Bernhard Gschaider
Yep. blockMesh is only one way to get a mesh. A converter like fluentMeshToFoam is another. You only need one of those at a time
Old   July 26, 2012, 01:56
adambarfi's Avatar
Mostafa Mahmoudi
Oh damn. so I was fooled for 2 dayes!!!!! yes, I done it.
but I have many other problems and questions that if I cannot solve them, I will come back again!
Thank you Bernhard so much.
Map of the OpenFOAM Forum - Understanding where to post your questions! wyldckat OpenFOAM 10 September 2, 2021 05:29
[Other] How to use finite area method in official OpenFOAM 2.2.0? Detian Liu OpenFOAM Meshing & Mesh Conversion 4 November 3, 2015 03:04
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 cfd.direct OpenFOAM Announcements from Other Sources 2 August 31, 2015 13:36
friction forces icoFoam ofslcm OpenFOAM 3 April 7, 2012 10:57
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 06:55
