[mesh manipulation] export mesh
Old   August 23, 2012, 11:53
Default export mesh
sukye is on a distinguished road
I have generated mesh via snappyHexMesh from a .stl geometry file. How can I export the mesh to other format, eg .hdf or .UNV?
Thanks,
sukye is offline   Reply With Quote
Old   August 23, 2012, 13:50
Retired Super Moderator
Bruno Santos
Hi Sukye,
Here are two lists of the ones currently catalogued at openfoamwiki.net:
Best regards,
Bruno
Old   August 23, 2012, 14:07
Thank you Bruno,
Yes, I have noticed this and use FoamMeshToFluent to generate a msh file. But my salome did not recognize it...
Originally Posted by wyldckat View Post
Hi Sukye,
Best regards,
Bruno
Old   August 23, 2012, 14:30
Bruno Santos
I think the only solution is to create the utility foamToIdeasUnv
If so far such utility doesn't exist yet, it's because this isn't the usual need.
Or you could convert the surface mesh from OpenFOAM and then re-mesh in Salome... The utility is named surfaceMeshConvert.
Old   August 23, 2012, 14:50
The valid types of surfaceMeshConvert do not include msh or hdf.
I think the problem lies in salome, not openfoam. I installed caelinux in which salome only reads hdf files.
Old   August 29, 2012, 03:53
Elvis
elvis will become famous soon enough
but I think that surfaceMeshConvert creates an STL that can be imported into salome and by saving your imported STL you have an HDF-file.
Do you want to do a Fluid Structure Interaction (FSI) simulation, otherwise I do not understand why you want to import from OF to Salome! If the mesh you used for snappy hex mesh did not deform during simulation you could use directly your original STL for Salome import STL-file save as HDF-File and mesh for FEM-simulation
elvis is offline   Reply With Quote
Old   August 29, 2012, 10:16
Thank you Elvis.
I use Salome in CAELinux where it can only read hdf files. weird!
Yes, you are right I dont have to export from OF. But I dont know how to define inlets and outlets in OF. There is no example of a pipe flow. Maybe I was wrong?
Originally Posted by elvis View Post
Old   August 30, 2012, 07:12
Elvis
you are looking for
setSet
Manipulate a cell/face/point/ set or zone interactively
setsToZones
Add pointZones/faceZones/cellZones to the mesh from similar named pointSets/faceSets/cellSets
Old   August 31, 2012, 05:37
Bruno Santos
Greetings to all!
To complement Elvis' response - you can find several tutorials on creating patches after the mesh has been created!
Run the following command to see which ones they are:
find $FOAM_TUTORIALS -name createPatchDict
As for pipe, it really depends on what you're looking for. I know of a few tutorials that fit the description:
basic/scalarTransportFoam/pitzDaily
basic/potentialFoam/pitzDaily
compressible/rhoPimpleFoam/les/pitzDaily
combustion/XiFoam/les/pitzDaily3D
incompressible/simpleFoam/pitzDaily
incompressible/simpleFoam/pitzDailyExptInlet
incompressible/pisoFoam/les/pitzDailyMapped
incompressible/adjointShapeOptimizationFoam/pitzDaily
incompressible/icoFoam/elbow
incompressible/pimpleFoam/TJunction
incompressible/pimpleFoam/TJunctionFan
Best regards,
Bruno
Old   August 31, 2012, 13:06
Thank you Elvis and Bruno.
Yes, setSet may do the job.
I also followed this link: http://openfoamwiki.net/index.php/SetSet.
But the inlets do not have their names under
foamJob -s checkMesh -allTopology -allGeometry
The reason is, I accept everything from the tutorial moterbike, and replace the bike geometry by my vessel model, whose mesh is generated by snappy via its stl file. So, the vessel only have one face in OF.
Should I generate mesh in another way?
Have a good holiday!
PS, if someone can help today, I will have a good one myself
you are looking for
setSet
setsToZones
Old   August 31, 2012, 14:29
Thank you so much.
How can I transfer the mesh from current folder to the destination folder? Or I can generate mesh from stl file, but there is no triSurface folder for snappy in the tutorials you mentioned ...
Greetings to all!
Best regards,
Bruno
Old   August 31, 2012, 18:30
Bruno Santos
createPatch is meant to be used after the mesh has been created. Keep in mind that createPatch relies on sets created by setSet or topoSet.
You can also try surfaceToPatch, which is also meant to be applied after the mesh is done. For more:
surfaceToPatch -help
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
Export 2D mesh from ICEM to Fluent BuilttoSpill ANSYS Meshing & Geometry 4 August 28, 2010 08:16
2D mesh export of an original 3D model Yogendra Shastri Main CFD Forum 0 February 22, 2008 13:14
