[Commercial meshers] Fluent to OpenFoam Mesh converting |
September 27, 2012, 12:30 |
Rep Power: 14 |
I'm trying to convert fluent 3D mesh to OF, and I'm using fluent3DMeshToFOAM command(which I used it for my previous mesh converting) but I face following error: --> FOAM Warning : Found unknown block of type: "3010" on line 14 --> FOAM FATAL ERROR: Do not understand characters: ÿ on line 15 From function fluentMeshToFoam::lexer in file fluent3DMeshToFoam.L at line 748. FOAM exiting could you please help me? |
September 28, 2012, 14:32 |
Andrzej Prusiński
Rep Power: 14 |
Have you tried dos2unix_ first?
September 28, 2012, 14:33 |
Rep Power: 14 |
No, what is that?
September 28, 2012, 14:35 |
Rep Power: 14 |
I converted other meshed geometries from Ansys workbench to OF. they are fine, and I did the same for new file, but it did not work.
May 8, 2013, 06:47 |
Matteo Colli
Rep Power: 13 |
I've got exactly the same problem. Did you solved it?
I also tried dos2unix on the .msh file but it returns: dos2unix: Skipping binary file FFF.1.msh Any suggestion on the source of the conversion error? |
May 20, 2014, 05:04 |
Michał
Rep Power: 12 |
@supercolli
It seems to me that your .msh file is written as a binary, not ASCII file. While saving/exporting you should probably uncheck "write binary files" option or change preferences somewhere else (e.g. in Tools in Ansys Mesher). |
[Salome] Script for converting a mesh from Salome-Platform to OpenFOAM | nsf | OpenFOAM Meshing & Mesh Conversion | 86 | February 8, 2023 10:30 |
Fluent converting 'wall' to 'interior' BC for hybrid mesh | DarrenC | FLUENT | 8 | January 3, 2019 06:24 |
Very small job: converting an OpenFOAM mesh to a format needed by another code | SFr | CFD Freelancers | 1 | June 24, 2016 05:45 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
[CAD formats] Converting .gtm mesh for use in OpenFOAM | EVBUCF | OpenFOAM Meshing & Mesh Conversion | 0 | December 20, 2012 17:17 |
