[Other] converting interfaces to ami
Old   September 30, 2012, 08:33
Default converting interfaces to ami
Hossein
atoof is on a distinguished road
Send a message via Yahoo to atoof
Dears,
Can I convert a gambit mesh to OF2.1.x and then change the interface boundaries that defined in gambit to the ami bounadries in the boundary dictionary. I want to use it for dynamic mesh in OF.
Best Regard,
Hossein
atoof is offline   Reply With Quote
Old   March 9, 2013, 19:16
hz283 is on a distinguished road
Hi Hossein,
Have you solved that problem you mentioned in the thread? I have the same problem. I generated the mesh for multiply bodies (multiply bodies) using ICEM. The interfaces between neighboring bodies have non matched grid nodes. So I would like to use AMI but the interface itself does not move during the simulations. Do you know how to convert the interface into AMI in openfoam?
best regards,
H
Originally Posted by atoof View Post
Dears,
Best Regard,
Hossein
hz283 is offline   Reply With Quote
Old   April 24, 2013, 05:15
Andreas Wendy
A.Wendy is on a distinguished road
never used a gambit mesh before but can't you just modify the boundary file in contant/polymesh and the U,p, etc files in the 0 folder in a text editor?
maybe you can upload these files and i can try?
Andreas
A.Wendy is offline   Reply With Quote
mapField error rvl565 OpenFOAM Pre-Processing 1 September 6, 2018 16:13
Translating and Rotating AMI HiddenSquid OpenFOAM Pre-Processing 1 October 25, 2017 03:59
AMI Motions: Ramped Rotation Speeds and Nested Sliding Interfaces lordvon OpenFOAM Programming & Development 0 September 24, 2013 01:30
dynamic Mesh is faster than MRF???? sharonyue OpenFOAM Running, Solving & CFD 14 August 26, 2013 07:47
mixerVesselAMI2D's mass is not balancing sharonyue OpenFOAM Running, Solving & CFD 6 June 10, 2013 09:34
