[blockMesh] blockMesh Mesh and Simulation
Old   October 15, 2012, 11:32
Default blockMesh Mesh and Simulation
Luca Polverini
fotoflash is on a distinguished road
my name is Luca and I'm new in openFoam.
Could I have some help in building a mesh using blockMesh? The mesh is like the one atacched.
mesh.pdf
Kind regards,
FF
fotoflash is offline   Reply With Quote
Old   October 16, 2012, 03:09
colinB is on a distinguished road
Hi Luca,
welcome to the forum.
First a general note: the guys here in the forum won't make your homework,
but they will help you with problems!
Since you are new to OF I recommend you to accomplish the tutorials
as mentioned in the user guide. Especially the first two should be
very helpful to you (Lid Driven Cavity & Stess Analysis)
The first one is good to get a general feeling for OF and the second one
is a good basis for your meshing problem.
http://www.openfoam.org/docs/user/ (here you find the user guide)
I hope the above is of assistance
regards
colinB is offline   Reply With Quote
Old   October 16, 2012, 04:34
Luca Polverini
Hi Colin,
thank you for replying me.
I've done the first tutorials but I have a lot of doubts.
Are there other docs on mesh?
Kind regards,
LP
Old   October 17, 2012, 02:36
Well, in the user guide, there is also a section that
covers meshing with blockMesh and explaining all
the parameters you can use.
Actually this is one of the most detailed chapters of
the whole guide and it is possible to understand blockMesh
completely just by reading this section. (I know it from my own experience)
Old   November 11, 2012, 08:06
RajaShankar
rajashankar.s is on a distinguished road
Hi
I am new to openFoam.
i want to do Fluid flow analysis over an rc a/c model.
i have my geometry in .stl format. how to create mesh around the body using block mesh
with regards
Raja
rajashankar.s is offline   Reply With Quote
Old   November 11, 2012, 08:23
akidess's Avatar
Anton Kidess
akidess will become famous soon enough
Not at all. Use snappyHexMesh.
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
akidess is offline   Reply With Quote
Old   November 11, 2012, 08:29
RajaShankar
Hi akidess
Thank you akidess.
Actually i am tryimg so.
But i not getting clearly about some keywords in snappy Hex mesh dictionary.
any detailed tutorial is available for snappy Hexmesh
with regards
Raja
Old   November 12, 2012, 16:55
Retired Super Moderator
Bruno Santos
Greetings to all!
Several sources of information about snappyHexMesh are gathered here: http://openfoamwiki.net/index.php/SnappyHexMesh
Best regards,
Bruno
Mapping Field Data for Mesh Regions from Another Simulation veterator OpenFOAM Pre-Processing 1 July 10, 2018 05:28
Star CCM Overset Mesh Error (Rotating Turbine) thezack Siemens 7 October 12, 2016 11:14
Fatal overflow error, singularity, due to local mesh form? Thomasbr CFX 7 July 8, 2016 09:57
Mesh replacement in sub-domains while cfx simulation is in progress chiragsvnit CFX 4 December 11, 2015 12:25
Problem w/ vortex ring simulation, mesh coarseness parameters? ESC FLUENT 2 September 4, 2012 10:56
