[blockMesh] M4 / blockMesh
Old   November 23, 2012, 09:01
Default M4 / blockMesh
pythag0ra5 is on a distinguished road
Hi there,
can someone tell me if it is possible to calculate the arctan of some value in the M4 Preproccesor?
define(height_step, 1.5)
define(length_step, 3)
define(alpha, calc(atan(height_step/length_step)))
If i compile my m4-file with
m4 blockMeshDict.m4 > blockMeshDict
an error occurs:
Undefined subroutine &main::atan called at -e line 1.
In the final blockmeshdict nothing is calculated.
Can someone help?
Thanks a lot in advance!
pythag0ra5 is offline   Reply With Quote
Old   November 23, 2012, 09:24
Thanks a lot to startingwithCFD who gave the right hint, some perl-information was missing in the header:
define(calc, [esyscmd(perl -e 'use Math::Trig; print ($1)')]) dnl>
[OpenFOAM.org] blockMesh issue on openfoam6 startup - ubuntu 16.04 bjdarrer OpenFOAM Installation 7 August 25, 2020 19:15
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 14:53
[blockMesh] External flow around cube with blockMesh Woody8 OpenFOAM Meshing & Mesh Conversion 0 March 31, 2015 14:54
[blockMesh] set of xyz data in blockMesh psk OpenFOAM Meshing & Mesh Conversion 12 August 27, 2013 08:37
Blockmesh cavity error message tonitoney OpenFOAM Installation 2 March 17, 2008 11:59
