[blockMesh] stitchMesh question?
Old   December 9, 2012, 23:41
Question stitchMesh question?
Vishal Achasrya
vishalsacharya is on a distinguished road
I have a question about stitchMesh.
I have a sector geometry which has a centerline. Now when i rotatemesh and i paste, the centerline edge and nodes are common, so i assume they are not being repeated and that stitchMesh recognizes this. Now in the end when i need to stich the final internal faces that overlap to complete the geometry, i get an error....
Face XXXX reduced to less than 3 points.
Now im researched this in the forum and i see that there are others who have faced this error, but i dont see any where the geometry involved the centerline. Im thinking that this error is related to my centerline?
My mesh was created in gambit with a 45 degree sector that i initially used in a cyclic fashion. I converted to foam format. I have rotated and merged meshes and then stitched faces successfully for 7 times now. But the last stitch which is to stitch the final internal faces that overlaps, gives this error. I dont know why.
I also have another question. If i have faces inside a mesh that are internal and perfectly overlap, can i mark them to be translational periodic? I ask this as a last resort if in case there is no way to fix the above issue. I am assuming this would still be physical in terms of solving?
Please do not hesitate to ask any info that i failed to mention here. note that i do not have a blockmeshdict.
Thanks in advance !
vishalsacharya is offline   Reply With Quote
mergemeshes, stitchmesh
[mesh manipulation] stitchMesh: multiple meshes GerhardHolzinger OpenFOAM Meshing & Mesh Conversion 3 August 25, 2017 12:43
small question about the functionalities of topological changes in OpenFoam ngj OpenFOAM Running, Solving & CFD 2 February 28, 2013 10:02
Question Re Engineering Data Source imnull ANSYS 0 March 5, 2012 13:51
internal field question - PitzDaily Case atareen64 OpenFOAM Running, Solving & CFD 2 January 26, 2011 15:26
Poisson Solver question Suresh Main CFD Forum 3 August 12, 2005 04:37
