[snappyHexMesh] SnappyHexMesh cell removal
Old   December 12, 2012, 08:19
Default SnappyHexMesh cell removal
Ali
ali.ghaemi is on a distinguished road
Hi
I have a triangulated surface in STL format. SnappyHexMesh generates a mesh outside the surface and removes the cells that are located inside like Fig.5-12 in OpenFoam user guide. However since I need to do the simulation inside I want to retain the cells there and remove the ones outside the surface. I wonder if someone knows how to do that.
Thanks in advance
ali.ghaemi is offline   Reply With Quote
Old   December 12, 2012, 09:22
stephane sanchi
openfoam_user is on a distinguished road
edit your system/snappyHexMeshDict file and modify the following line:
locationInMesh (-1.0 0.0 3.5 );
The location must be where you want to keep the cells.
Regards,
Stephane.
openfoam_user is offline   Reply With Quote
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field lakeat OpenFOAM Community Contributions 58 December 23, 2021 02:36
[snappyHexMesh] Creating multiple multiple cell zones with snappyHexMesh - a newbie in deep water! divergence OpenFOAM Meshing & Mesh Conversion 0 January 23, 2019 04:17
[snappyHexMesh] Problem with SnappyHexMesh Cell Removal MoeCFD OpenFOAM Meshing & Mesh Conversion 0 July 7, 2017 12:55
[snappyHexMesh] Problem with snappyhexMesh: modelling a pore chamber and pore throat model Saideep OpenFOAM Meshing & Mesh Conversion 5 May 10, 2015 14:46
Journal file error magicalmarshmallow FLUENT 3 April 4, 2014 12:25
