March 5, 2013, 20:38 |
blockMesh pipe problem
yu
Rep Power: 15 |
Hello All
I am trying to use blockMesh to create a pipe. My blockMeshdict file is shown. It runs and I can see a pretty good cylinder from paraFoam. However, when I checkMesh, it fails. Code:
***Open cells found, max cell openness: 1, number of open cells 330 <<Writing 330 non closed cells to set nonClosedCells <<Writing 120 cells with high aspect ratio to set highAspectRatioCells Mesh non-orthogonality Max: 180 average: 35.0101 ***Number of non-orthogonality errors: 801. <<Writing 801 non-orthogonal faces to set nonOrthoFaces ***Error in face pyramids: 1620 faces are incorrectly oriented. <<Writing 819 faces with incorrect orientation to set wrongOrientedFaces Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.7.0 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 1; vertices ( // pipe centerl octagon (0 0 0) // 0 (1 0 0) // 1 (1 0.05 0) // 2 (0 0.05 0) // 3 (0 0 0.05) // 4 (1 0 0.05) // 5 (1 0.0353553 0.0353553) // 6 (0 0.0353553 0.0353553) // 7 (0 0 -0.05) //8 (1 0 -0.05) //9 (1 0.0353553 -0.0353553) //10 (0 0.0353553 -0.0353553) //11 (0 -0.05 0) //12 (1 -0.05 0) // 13 (1 -0.0353553 -0.0353553) // 14 (0 -0.0353553 -0.0353553) // 15 (0 -0.0353553 0.0353553) // 16 (1 -0.0353553 0.0353553) // 17 // outer octagon (0 0 0.1) // 18 (1 0 0.1) // 19 (1 0.0707107 0.0707107) // 20 (0 0.0707107 0.0707107) // 21 (0 0.1 0) //22 (1 0.1 0) //23 (0 0.0707107 -0.0707107) // 24 (1 0.0707107 -0.0707107) // 25 (1 0 -0.1) // 26 (0 0 -0.1)// 27 (0 -0.1 0) // 28 (1 -0.1 0) // 29 (1 -0.0707107 -0.0707107) // 30 (0 -0.0707107 -0.0707107) // 31 (0 -0.0707107 0.0707107) //32 (1 -0.0707107 0.0707107) // 33 ); blocks ( // center up right block hex (0 1 2 3 4 5 6 7) (30 3 3) simpleGrading (1 1 1) // center up left block hex (8 9 10 11 0 1 2 3) (30 3 3) simpleGrading (1 1 1) // center down left block hex (15 14 9 8 12 13 1 0) (30 3 3) simpleGrading (1 1 1) // center down right block hex (16 17 5 4 12 13 1 0) (30 3 3) simpleGrading (1 1 1) // outer up right lower block hex (4 5 6 7 18 19 20 21) (30 3 3) simpleGrading (1 1 1) // outer up right higher block hex (3 2 23 22 7 6 20 21) (30 3 3) simpleGrading (1 1 1) // outer up left higher block hex (11 10 25 24 3 2 23 22) (30 3 3) simpleGrading (1 1 1) // outer up left lower block hex (27 26 25 24 8 9 10 11) (30 3 3) simpleGrading (1 1 1) // outer down left higher block hex (31 30 26 27 15 14 9 8) (30 3 3) simpleGrading (1 1 1) //outer donw left lower block hex (31 30 14 15 28 29 13 12) (30 3 3) simpleGrading (1 1 1) //outer donw right lower block hex (28 29 13 12 32 33 17 16) (30 3 3) simpleGrading (1 1 1) //outer donw right higher block hex (32 33 17 16 18 19 5 4) (30 3 3) simpleGrading (1 1 1) ); edges ( // at inlet arc 18 21 (0 0.038269 0.092388) arc 21 22 (0 0.092388 0.038269) arc 22 24 (0 0.092388 -0.038269) arc 24 27 (0 0.038269 -0.092388) arc 27 31 (0 -0.038269 -0.092388) arc 31 28 (0 -0.092388 -0.038269) arc 28 32 (0 -0.092388 0.038269) arc 32 18 (0 -0.038269 0.092388) // at outlet arc 19 20 (1 0.038269 0.092388) arc 20 23 (1 0.092388 0.038269) arc 23 25 (1 0.092388 -0.038269) arc 25 26 (1 0.038269 -0.092388) arc 26 30 (1 -0.038269 -0.092388) arc 30 29 (1 -0.092388 -0.038269) arc 29 33 (1 -0.092388 0.038269) arc 33 19 (1 -0.038269 0.092388) ); patches ( patch inlet ( (4 7 3 0) (0 3 11 8) (0 8 15 12) (4 0 12 16) (21 7 4 18) (22 3 7 21) (24 11 3 22) (27 8 11 24) (31 15 8 27) (28 12 15 31) (12 28 32 16) (16 32 18 4) ) patch outlet ( (1 2 6 5) (9 10 2 1) (13 1 9 14) (5 1 13 17) (5 6 20 19) (2 23 20 6) (10 25 23 2) (26 9 10 25) (30 14 9 26) (29 13 14 30) (33 17 13 29) (19 5 17 33) ) wall wall ( //(4 5 6 7) //(7 6 2 3) (18 19 20 21) (21 20 23 22) //(3 2 23 22) (22 23 25 24) (24 25 26 27) //(3 2 10 11) //(11 10 9 8) //(27 26 9 8) //(4 5 19 18) (27 26 30 31) (31 30 29 28) //(8 9 14 15) //(15 14 13 12) //(28 29 13 12) //(4 5 19 18) //(12 13 17 16) //(16 17 5 4) (28 29 33 32) (32 33 19 18) ) ); mergePatchPairs ( ); // ************************************************** *********************** // thank. Last edited by wyldckat; May 24, 2014 at 02:40. Reason: Added [CODE][/CODE] |
March 5, 2013, 22:51 |
yu
Rep Power: 15 |
I figured it out. It was a ordering problem for one of the blocks that I have. as always, usually it is the block ordering problem.
March 8, 2013, 18:41 |
#3 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
paraFoam -block
May 23, 2014, 20:36 |
Cylinder BlockMesh
#4 | |
Rep Power: 13 |
July 1, 2014, 19:46 |
nakku
Rep Power: 11 |
I have some questions. What are your dimensions for pipe mesh? I mean what is your pipe diameter and length that you used for mesh? I have a pipe mesh problem it has D=4.5 mm and L=970 mm. Could you help me about these questions? Thank you. |
July 20, 2014, 16:42 |
Rep Power: 13 |
Hi, sorry for the delay of my reply. are you working with snappyHexMesh? mine is D=0.26m and L=0.56m, these are the dimensions of the outer pipe, it has another cylinder in it, it's kind of concentric cylinder. I have worked with a STL file
regards |
July 22, 2014, 23:50 |
#7 | |
nakku
Rep Power: 11 |
I do not use snappyHexmESH but, I want to learn and use it as soon as possible.If possible, could you please share your mesh? I think, it will be a good start for me. Thank you |
3D Pipe Flow Problem: Velocity profile is not symmetric | malicemethods | FLUENT | 0 | May 27, 2015 11:51 |
[ANSYS Meshing] mesh a pipe problem | ztdep | ANSYS Meshing & Geometry | 2 | January 13, 2015 03:08 |
Problem with 3D Pipe Flow | giorgia | FLUENT | 0 | April 30, 2014 04:02 |
simple pipe problem | kantipudi | Main CFD Forum | 2 | April 7, 2008 14:30 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
