[Commercial meshers] About how to handle the interior face in Openfoam |
March 9, 2013, 16:27 |
Rep Power: 13 |
Hi All,
Now I had a problem about how to deal with the "interface" or "interior" faces in Openfoam. The Problem is like this: I used ICEM to generate the meshes. Since the computational domain is complex and so I divided into the domain into several bodies. I generated the meshes for each body and then merge them together. Since the nodes belonging to the two neighboring bodies are not matched. I used "move nodes" to make them coincide. I tested this method using fluent and it seemed it is OK. But this mesh is read by Openfoam, the error message is like this: Cannot find metach for first face. cell model: tet first model face 3(1 2 3) mesh face: 4 ( ..... ... ... ... ) I also tried the mesh with the interface nodes not moved by "move nodes" and this error does not appear. I have tried to get some solutions for this: 1, try to improve the mesh using ICEM ? (using this method means that I should make the nodes on the interface metached from two sides) 2, using AMI to deal with the non-conformal mesh ? I checked the tutorials (http://www.openfoam.org/version2.1.0/ami.php) for AMI, but I found there is always another file about topoSet. Is this file particularly for AMI? (using this method means that it is not necessary to make the nodes matched.) I think the interface or interior face between different bodies or mesh regions are common. But I do not know which method is the best way for Openfoam ? Does anybody know something about this? Any suggestions and comments are welcome! best regards, H Last edited by hz283; March 10, 2013 at 06:13. |
March 10, 2013, 06:13 |
#2 | |
Rep Power: 13 |
Hi All,
Does anybody know something about this? best regards, H Quote:
March 10, 2013, 07:03 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings hz283,
I've moved your thread to the sub-forum that is dedicated for other meshers and OpenFOAM. You can find the sub-forum by going to: On this sub-forum you can find the following threads :
If not, I suggest that you create a simple test case that shows the problem you're having and share it with us, so that it's easier to help you find the solution with some trial-and-error. Best regards, Bruno
March 10, 2013, 07:14 |
#4 | |
Rep Power: 13 |
Hi Bruno,
Actually I have done the test using the a backstep by ICEM. I divided the whole computational domain into three bodies: nozzle, step and exit. There are two interfaces between nozzle and step, step and exit, respectively. And then I generate the mesh body by body, then merge them in ICEM. I tried two methods: 1,in ICEM, I make the grid nodes from two bodies matched. Then output the mesh and set the interface face to be "interior", output the fluent format mesh. I used fluent to read the mesh. It is OK, but it is not when I used Openfoam. 2, I did not make the grid nodes matched and then output the fluent format mesh. The openfoam can read in without any error (I did not run it) but fluent will show errors. I can share my fluent format mesh but I do not know how to upload it. Thank you. H Quote:
March 10, 2013, 07:23 |
#5 | |
Bruno Santos
Rep Power: 128 |
website. All of the big companies now have it... some examples:
March 10, 2013, 07:39 |
#6 | |
Rep Power: 13 |
Thank you so much, Bruno!
Just now I think I found that solution: For multi-body meshes from ICEM, we can merge the grid nodes from two bodies at the interface face and then use the command fluent3DMeshToFoam. But I am not sure if the following method can work or not: Do not merge the mesh nodes at the interfaces and then AMI in openfoam. Any comments are welcome. Thank you again. H Quote:
March 26, 2013, 10:49 |
Paul Schroder
Rep Power: 13 |
This sounds a lot like a problem I have. I made a Fluent mesh and imported it using Fluent3DMeshToFoam. That worked fine. But I have a conjugate heat transfer problem, and if I make the fluid and solid meshes from 2 separate parts, I get no heat transfer across the interface. If I make the mesh from 2 bodies in a single part, OpenFOAM gives me an error related to the interface. It looks like "wall instead of mappedPatchBase". Does anyone know how to solve this?
April 1, 2013, 08:08 |
#8 | |
Bruno Santos
Rep Power: 128 |
Greetings Paul,
Best regards, Bruno
May 2, 2013, 10:58 |
#9 |
Rep Power: 14 |
Hello, for everyone.
I want share my solution of converting ICEM CFD hex mesh to OpenFOAM mesh. At start I have same problem as: Cannot find metach for first face. cell model: tet first model face 3(1 2 3) mesh face: 4 ( ... ... ) The solution was found thanks to this amazing forum and all of its users. So my recipe is like that. 1. Prepare mesh in ICEM CFD with all name selections 2. Export it to FLUENT_V6 (for my present experience, you don’t need specify BC in Output -> Boundary Condition (If I am wrong, please correct me)) 3. Read mesh in FLUENT 4. Modify names of BC 4a. If you case is multi region (like chtMultiregionFoam). In FLUENT change type of coupled wall. From Wall to Interior (+ add interior- prefix to its name) 5. Change write-type to ascii “file/ binary-files? no” 6. Write .cas file 7. In OpenFOAM work directory 7a. fluentMeshToFoam –wrireZones fluent.cas 7b. splitMeshRegions -cellZones -overwrite That’s ALL ))) |
OpenFOAM 5.0 Released | CFDFoundation | OpenFOAM Announcements from OpenFOAM Foundation | 11 | June 5, 2018 23:48 |
OpenFOAM Training, London, Chicago, Munich, Houston 2016-2017 | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | September 14, 2016 03:19 |
OpenFOAM Training: Programming CFD Course 12-13 and 19-20 April 2016 | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | January 14, 2016 10:19 |
64bitrhel5 OF installation instructions | mirko | OpenFOAM Installation | 2 | August 12, 2008 18:07 |
OpenFOAM Training and Workshop Zagreb 2628Jan2006 | hjasak | OpenFOAM | 1 | February 2, 2006 21:07 |
