[snappyHexMesh] snappy works but does not add layers...why?
Old   March 25, 2013, 05:28
Default snappy works but does not add layers...why?
sandy
sandy13 is on a distinguished road
Dear foamers,
Please any body can help me. My snappy utility for my work, but it does not add layers. My geometry and the snappy is like in photos, can any one have a go on my snappy dictionary below..
| \\ / O peration | Version: 2.1.1 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object snappyHexMeshDict;
castellatedMesh true;
snap true;
addLayers true;
geometry
injector.stl
type triSurfaceMesh;
name injector;
castellatedMeshControls
maxLocalCells 500000;
maxGlobalCells 1000000;
minRefinementCells 100;
nCellsBetweenLevels 6;
features
refinementSurfaces
injector
level (4 3);
refinementRegions
resolveFeatureAngle 200;
locationInMesh (0 0 0);
allowFreeStandingZoneFaces false;
snapControls
nSmoothPatch 3;
tolerance 4;
nSolveIter 60;
nRelaxIter 5;
addLayersControls
relativeSizes true;
layers
injector
nSurfaceLayers 4;
}/*--------------------------------*- C++ -*----------------------------------*\
FoamFile
version 2.0;
format ascii;
class dictionary;
snap true;
addLayers true;
geometry
injector.stl
name injector;
features
refinementSurfaces
injector
level (4 3);
refinementRegions
snapControls
nSmoothPatch 3;
tolerance 4;
nSolveIter 60;
nRelaxIter 5;
addLayersControls
relativeSizes true;
layers
injector
nSurfaceLayers 4;
expansionRatio 1.0;
finalLayerThickness 0.3;
minThickness 0.1;
nGrow 1;
featureAngle 30;
nRelaxIter 3;
nSmoothSurfaceNormals 1;
nSmoothNormals 3;
nSmoothThickness 10;
maxFaceThicknessRatio 0.5;
maxThicknessToMedialRatio 0.3;
minMedianAxisAngle 130;
nBufferCellsNoExtrude 1;
nLayerIter 50;
meshQualityControls
maxNonOrtho 65;
maxBoundarySkewness 20;
maxInternalSkewness 4;
maxConcave 80;
minVol 1e-13;
minTetQuality 1e-30;
minArea -1;
minTwist 0.05;
minDeterminant 0.001;
minFaceWeight 0.05;
minVolRatio 0.01;
minTriangleTwist -1;
nSmoothScale 4;
errorReduction 0.75;
minFlatness 0.5;
debug 0;
mergeTolerance 1e-6;
expansionRatio 1.0;
minThickness 0.1;
nGrow 1;
featureAngle 30;
nRelaxIter 3;
nSmoothNormals 3;
nLayerIter 50;
meshQualityControls
maxNonOrtho 65;
maxConcave 80;
minVol 1e-13;
minArea -1;
minTwist 0.05;
minFaceWeight 0.05;
minVolRatio 0.01;
nSmoothScale 4;
minFlatness 0.5;
debug 0;
Sandy,
sandy13 is offline   Reply With Quote
Old   March 25, 2013, 16:18
Retired Super Moderator
Bruno Santos
Quick answer: Check the second tutorial at this page: http://openfoamwiki.net/index.php/Sn...als_and_Guides - namely the one from the 7th OpenFOAM Workshop
Old   May 16, 2013, 05:17
Default help
sh.d is on a distinguished road
hi sandy
i create geometry in solid and save it .stl
but when open in linux its there is wrong
can you help me?
sh.d is offline   Reply With Quote
Old   May 16, 2013, 05:35
Default ascci stl
sandy
Originally Posted by sh.d View Post
hi sandy
can you help me?
Dear sh.d,
In fact I do not why your file does not open with linux, but have you saved your file as an ascci format stl file. I think you should pick ascci when you save the file If you did not and I wish If I can help you more.
Sandy,
Old   May 17, 2013, 08:07
Default help
Hi sandy
Thank you very much for answering my question. But I do not know how to save your file format ascci?
Do you know?
Old   May 17, 2013, 09:19
Default ascii format
sandy
Hi sandy
Do you know?
Okay, you mad your geometry by solid works and saved it in STL. now go to linux and use blender software. In blender import this STL file and open it you will see your geometry the export it as an STL and in the exporting window there is option of ascii, pick this option and unpick apply modifiers, so you will get it and then you can use it in OF.
Sandy,
Old   May 17, 2013, 10:01
Sandy,
thank you very very much sandy
Old   May 17, 2013, 10:42
Dear sany
i import my geometry in blender but i cant see it!!!!!!!!!!!!!!!!!!
i open it
the all normal face is (0 0 0)
is it right?
File Type: zip New Folder 2.zip (599 Bytes, 8 views)
Last edited by wyldckat; May 17, 2013 at 17:40. Reason: too many consecutive posts with very little information... so they've been merged accordingly
Old   May 20, 2013, 06:18
Default It is working
sandy
Dear sany
i open it
is it right?
Hi, I imported your geometry, it is working, I do not know what is going on with you, It should work...,
Sandy
Old   May 25, 2013, 09:56
Hi Sandy
Do you know how to use Add layer?
thanks a lot
Old   May 26, 2013, 06:29
Default Add layers
  #11
sandy
Hi Sandy
thanks a lot
Hi, I never succeeded in adding layers, sorry I can not help you that much about it but If you manged to do it please post me...
Sandy,
Old   May 26, 2013, 06:39
Nima Samkhaniani
nimasam is on a distinguished road
Hi Sandy
thanks a lot
first :
addLayers       true;
second: in addLayersControls
     layers
        ".*" //put your patch name here
            nSurfaceLayers 1; //put numbers of your layers here
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
Old   May 26, 2013, 09:25
sandy
Originally Posted by nimasam View Post
first :
addLayers       true;
     layers
Hi, thank you so much for your post, I tried to do the same without any success, may be I have something wrong some where. Thank you so much.
Sandy,
Old   May 26, 2013, 10:44
Nima Samkhaniani
Hello
look at the following test case:
Old   May 26, 2013, 14:27
hi sandi
probably your name of addlayer is wrong
i think its true:
injector.stl_injector
second injector is the name in .stl file and not geometry
Old   May 27, 2013, 01:44
hello
sandy look at the .stl file and name it in the file and name add layer in snappyHexMeshDict file
Old   May 28, 2013, 04:06
Default snap
  #17
hi
i want to create 2d mesh around airfoil
but when i use checkMesh is this error:Number of edges not aligned with or perpendicular to non-empty directions
and the surface of airfoil not snap
can you help me please?
Old   May 28, 2013, 04:26
Nima Samkhaniani
hi
did you try to use extrudeMesh ?
Old   May 28, 2013, 07:16
sandy
Dear searcher,
Sorry I can not help you that much about this error, and I did not use extrudeMesh before, sorry again and good luck with your research.
Sandy,
Old   May 28, 2013, 07:30
Default snap
  #20
Hi nimasam
yes i use the extrudMesh
please look at the my testcase
[snappyHexMesh] Impossible to add layers in SnappyHexMesh knightwalker OpenFOAM Meshing & Mesh Conversion 4 March 27, 2019 17:09
[OpenFOAM] Checking layers generated by snappy with paraview bentkj ParaView 1 February 22, 2018 03:32
[snappyHexMesh] snappy does not add layer to whole body 5tern OpenFOAM Meshing & Mesh Conversion 0 October 20, 2016 10:09
[snappyHexMesh] Adding layers goes wrong with SnappyHexMesh Elise OpenFOAM Meshing & Mesh Conversion 1 April 22, 2013 02:32
[snappyHexMesh] Add layers and deformation Prosiaczek OpenFOAM Meshing & Mesh Conversion 0 April 11, 2012 18:27
