[Other] Rotation of refinementRegions in Snappy
Old   December 13, 2013, 18:16
Default Rotation of refinementRegions in Snappy
Julian Langowski
Ruli is on a distinguished road
Dear Foamers,
once again I ask for help. Is there a way, to use e.g. a refinementBox and to rotate it? I have to refine a wake, which is rotated relative to the main coordinate frame. Which else would be a solution? Could I use an additional .stl files to refine it?
If I try searchablePlane_3points, which is desribed for example here:
https://sites.google.com/site/snappy...efined-regions
Terminal gives this output:
[0]
[0] --> FOAM FATAL IO ERROR:
[0] keyword embeddedPointsDict is undefined in dictionary "/home/julian/OpenFOAM/julian-2.2.2/run/mesh_MRF_20131212/processor0/../system/snappyHexMeshDict.geometry.plate"
[0]
[0] file: /home/julian/OpenFOAM/julian-2.2.2/run/mesh_MRF_20131212/processor0/../system/snappyHexMeshDict.geometry.plate from line 46 to line 52.
[0]
[0]     From function dictionary::subDict(const word& keyword) const
[0]     in file db/dictionary/dictionary.C at line 608.
[0]
Thanks again
Julian
Ruli is offline   Reply With Quote
Error while running pisoFoam with snappy but ran smoothly without snappy in empty dm faiazk OpenFOAM Running, Solving & CFD 0 October 24, 2018 13:51
Java Macro -- Passive Pith in Superposing Rotation Motion Weidong Dai STAR-CCM+ 2 August 4, 2018 05:39
Remeshing for Rotation in CFX via ICEMCFD gera CFX 3 September 23, 2017 12:29
[snappyHexMesh] snappy not using all refinementRegions and refinementSurfaces suryansh OpenFOAM Meshing & Mesh Conversion 0 June 6, 2016 06:20
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 06:21
