[Other] Mesh conversion from Pointwise to OpenFoam
Old   March 20, 2012, 05:20
Default Mesh conversion from Pointwise to OpenFoam
Gitesh
Gitesh P is on a distinguished road
Hello everyone,
I want to convert my mesh file from Pointwise to OpenFoam. I am doing with following steps,
1. Open the mesh file in Pointwise.
2. With CAE menu, select "Select Solver" and choose OpenFOAM.
3. Re-check boundary patch types.
4. Select all of the blocks and go to File --> Export --> CAE, navigate to a folder where I want to save files.
5. It generates boundary, faces, neighbour, owner and points files.
Then what to do next to open mesh in OpenFoam ?
Can anyone help me ?
With regards,
Gitesh
Gitesh P is offline   Reply With Quote
Old   March 31, 2012, 11:03
Elh. A2. BAH
ebah6 is on a distinguished road
put these five files in your constant/polyMesh directory.
Then you can use them as if they were generate from openfoam.
And make sure you boundary file is properly named to match you 0/* files names. edit if necessary.
Hope this helps.
Best regards.
ebah6 is offline   Reply With Quote
Old   April 29, 2013, 09:22
Milad MU
Milad06 is on a distinguished road
I have created the block mesh. I have chosen the boundary condition and volume condition as well but when I go to export_CAE it asks me for a folder. When I give a folder it says ERROR-Uninitialized block. I am new to pointwise so I will appreciate if you help me, thanks. By the way, I have already cells in my block. more than 900M cells.
Milad06 is offline   Reply With Quote
Old   April 29, 2013, 12:07
Elh. A2. BAH
The block is either not initialized as the error message says or you have the block icone unchecked in the tool bar. If the latter then when you are exporting the block is just not selected.
If you created your block using existing domains, you may need to select the block and initialize ( I guess) grid/initialize.
regards.
hybrid mesh created by pointwise fails mesh check in fluent due to left-handed faces Hamid.de Pointwise & Gridgen 4 November 9, 2016 11:20
[Commercial meshers] Problems with ANSYS mesh conversion tdog OpenFOAM Meshing & Mesh Conversion 1 March 31, 2016 17:36
[Other] Mesh Conversion: OpenFoam (polyMesh format) to Calculix gillers18 OpenFOAM Meshing & Mesh Conversion 2 April 24, 2015 03:37
Native OpenFOAM interface in Pointwise Chris Sideroff Main CFD Forum 0 January 16, 2009 12:37
