[Gmsh] How to obtain continuity in your subregions mesh---->Gmsh
Old   August 8, 2015, 00:04
Default How to obtain continuity in your subregions mesh---->Gmsh
tareqkh's Avatar
CFD
tareqkh is on a distinguished road
Hello Gmsher,
I hope that you all well. I am doing a validation study on a shrouded diffuser at 6 m/s. I have developed the domain and the shrouded diffuser geometry. Moreover, I have made sub-regions to make it easy to mesh. So far, I have done 80% of the problem, but I am still facing a problem to obtain a converged solution. I have run the case as a laminar and turbulent, I have not got a converged solution yet. My guess is properly because of the discontinuity of the sub-regions or it might be something not in my knowledge. I am asking if someone could guide me to obtain the converged solution (See the picture below). I am attaching a picture shows the strategy that I have used and hoping some guidance.
Thank in advance,
tareqkh is offline   Reply With Quote
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
[Gmsh] gmshToFoam problem: not the same mesh in Gmsh vs. paraview zhernadi OpenFOAM Meshing & Mesh Conversion 8 July 7, 2011 02:28
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 09:38
