[mesh manipulation] Problems with polyDualMes
Like Tree1Likes
  • 1 Post By chegdan
Old   June 11, 2013, 11:39
Default Problems with polyDualMes
Christoph_84 is on a distinguished road
I tried to convert a mesh, generated in ICEM with approx. 5.5 Mio. tet cells
Overall number of cells of each type:
      hexahedra:     0
      prisms:        0
      wedges:        0
      pyramids:      0
      tet wedges:    0
      tetrahedra:    5465917
      polyhedra:     0
after running the polyDualMesh command I got approx. 21.9 Mio. hex cells, not one poly cell. I tried different angles (60° 75° 90°) always with the same result.
      hexahedra:     21863668
      prisms:        0
      wedges:        0
      pyramids:      0
      tet wedges:    0
      tetrahedra:    0
      polyhedra:     0
Anyone an idea?
Christoph_84 is offline   Reply With Quote
Old   June 19, 2013, 16:26
Daniel P. Combest
chegdan will become famous soon enoughchegdan will become famous soon enough
polyDualMesh (PDM) can be picky sometimes. You really need to have a high-quality tet mesh for PDM to work reliably. This also means it must be a tet mesh without Delaunay violations (slide 15). Without knowing more about your mesh, you will just be left with guesses or people throwing links to the forum like these:
http://www.cfd-online.com/Forums/ope...eneration.html
http://www.cfd-online.com/Forums/ope...e-help-me.html
http://www.cfd-online.com/Forums/ope...ce-object.html
maybe you can run a
checkMesh -allGeometry -allTopology
in your imported mesh to the OpenFOAM case for more information and/or provide your mesh.
wyldckat likes this.
chegdan is offline   Reply With Quote
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 11:12
[mesh manipulation] Problems with rotational cyclic boundaries TReviol OpenFOAM Meshing & Mesh Conversion 8 July 11, 2014 03:45
[ICEM] Flow channel meshing problems StefanG ANSYS Meshing & Geometry 19 May 15, 2012 06:44
Two-phase air water flow problems by activating Wall Lubrication Force challenger85 CFX 5 November 5, 2009 05:44
Help required to solve Hydraulic related problems aero CFX 0 October 30, 2006 11:00
