[Technical] Questoion about nonMainfoldPoint and nonOrthoFaces
Old   June 24, 2013, 10:47
Default Questoion about nonMainfoldPoint and nonOrthoFaces
Filip Gjetvaj
File is on a distinguished road
I created a mesh with Avizo and then used Gmsh and enGrid to transform it to OpenFoam. When I try to run my case with this mesh it always fail but it works with other meshes. Therefore it is reasonable to assume that the problem is somewhere in the mesh
check Mesh writes Mesh OK, but I am concerned about nonMainfoldPoint and nonOrthoFaces which occur in my polyMesh folder. I cannot find any documentation regarding this topic so if somebody could tell me what to do or where to look for an answer
check Mesh gives output like
|  \\    /   O peration     | Version:  2.2.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 2.2.0-5be49240882f
Exec   : checkMesh
Date   : Jun 24 2013
Time   : 16:29:00
Host   : "zeus"
PID    : 7719
Case   : /home/filip/OpenFOAM/proba/moje_2
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create polyMesh for time = 0
Time = 0
Mesh stats
    faces:            947476
    internal faces:   875052
    cells:            455632
    faces per cell:   4
    boundary patches: 3
    point zones:      0
    face zones:       0
    cell zones:       0
Overall number of cells of each type:
    hexahedra:     0
    prisms:        0
    wedges:        0
    pyramids:      0
    tet wedges:    0
    tetrahedra:    455632
    polyhedra:     0
Checking topology...
    Boundary definition OK.
    Cell to face addressing OK.
    Point usage OK.
    Upper triangular ordering OK.
    Face vertices OK.
   *Number of regions: 4
    The mesh has multiple regions which are not connected by any face.
  <<Writing region information to "0/cellToRegion"
Checking patch topology for multiply connected surfaces...
    Patch               Faces    Points   Surface topology
    Inlet               1966     1143     ok (non-closed singly connected)
    Outlet              1962     1132     ok (non-closed singly connected)
    wall                68496    34516    multiply connected (shared edge)
  <<Writing 8 conflicting points to set nonManifoldPoints
Checking geometry...
    Overall domain bounding box (-5.2703e-07 -5.57384e-07 -5.82047e-07) (0.00141052 0.0014106 0.00141059)
    Mesh (non-empty, non-wedge) directions (1 1 1)
    Mesh (non-empty) directions (1 1 1)
    Boundary openness (1.4271e-17 4.92582e-17 -2.06799e-17) OK.
    Max cell openness = 2.7799e-16 OK.
    Max aspect ratio = 15.936 OK.
    Minimum face area = 1.72258e-11. Maximum face area = 1.07184e-09.  Face area magnitudes OK.
    Min volume = 5.78296e-17. Max volume = 1.01736e-14.  Total volume = 6.68254e-10.  Cell volumes OK.
    Mesh non-orthogonality Max: 78.3513 average: 21.5589
   *Number of severely non-orthogonal faces: 6.
    Non-orthogonality check OK.
  <<Writing 6 non-orthogonal faces to set nonOrthoFaces
    Face pyramids OK.
    Max skewness = 3.02936 OK.
    Coupled point location match (average 0) OK.
Mesh OK.
End
Regards
Filip
File is offline   Reply With Quote
