[mesh manipulation] Problem with RenumberMesh in parallel in OpenFOAM 2.1.1
Old   March 18, 2013, 07:01
Default Problem with RenumberMesh in parallel in OpenFOAM 2.1.1
Srinivas Nag H.V.
srini_esi is on a distinguished road
Dear All,
This is Srinivas.
I am using OpenFOAM 2.1.1 in RHEL 5.8
There are 4 procs in my system. blockMesh, snappyHexMesh, checkMesh transformPoints -scale are successful in parallel.
Then I did, mpirun -np 4 reconstructParMesh -mergeTol 1e-6 -constant.
Then, mpirun -n 4 renumberMesh -overwrite -parallel.
It fails with following message :
--> FOAM FATAL IO ERROR:
[3] keyword SIDE_GLASS is undefined in dictionary "/home/pv/Working_Directory/Renumber_mesh_problem/processor3/0/nut::boundaryField"
[3]
[3] file: /home/pv/Working_Directory/Renumber_mesh_problem/processor3/0/nut::boundaryField from line 26 to line 61.
[3]
[3] From function dictionary::subDict(const word& keyword) const
[3] in file db/dictionary/dictionary.C at line 461.
[3]
FOAM parallel run exiting
If I do just renumberMesh -overwrite, it works fine but parallel renumbering is a problem.
I request you all to please help me.
Thanks.
Best Regards,
Srini
srini_esi is offline   Reply With Quote
Old   November 8, 2013, 02:48
CFDnewbie147 is on a distinguished road
hello Srini,
my opinion:
you do you meshgeneration in parallel and then you reconstruct you mesh with reconstructParMesh => you get a Mesh which you can use with only one prozessor or you decompose it again to use parallel computation...
to renumber your reconstructed mesh you've to use the renumberMesh option without -parallel:
this command renumbers your RECONSTRUCTED mesh.
To use the command in parallel you have to reconstruct your mesh AFTER renumbering it with mpirun -np 4 renumberMesh -overwrite -parallel.
I hope this will help you.
Best regards,
CFDNewbie147
CFDnewbie147 is offline   Reply With Quote
Error running openfoam in parallel fede32 OpenFOAM Programming & Development 5 October 4, 2018 16:38
OpenFOAM 4.0 Released CFDFoundation OpenFOAM Announcements from OpenFOAM Foundation 2 October 6, 2017 05:40
How can i make a parallel programming in OpenFOAM? jignesh_thaker2007 OpenFOAM Running, Solving & CFD 3 July 2, 2014 09:37
Problem in parallel run with OpenFOAM Gitesh P OpenFOAM Running, Solving & CFD 2 June 1, 2014 06:05
Problem in recompiling a turbulence model in OpenFoam 2.1.1 pascool OpenFOAM Programming & Development 6 October 3, 2012 12:03
