[blockMesh] refinement of mesh around a half-cylinder-using blockMesh
Old   July 15, 2013, 08:25
Default refinement of mesh around a half-cylinder-using blockMesh
Amin
Mirage12 is on a distinguished road
i would like to refine the mesh around a half cylinder, that is why i used simpleGrading to refine the area near to the surface of the half-cylinder, in order to capture the boundary layer. however it is not working ...
here is my blockMeshDict :
// The OpenFOAM Project // File: blockMeshDict
   =========         | dictionary
    \\    /          | Name:   blockMeshDict
     \\  /           | Family: FoamX configuration file
      F ield         | OpenFOAM version: 2.3
      O peration     | Product of Nabla Ltd.
      A and          |
      M anipulation  | author: Amine Abd.
  // FoamX Case Dictionary.
  FoamFile
      version         2.0;
      format          ascii;
      root            "";
      case            "";
      instance        "";
      local           "";
      class           dictionary;
      object          blockMeshDict;
 convertToMeters 1;
  vertices
    (-0.5 0 0)//0
    (-0.353553 0.353553 0)//1
    (0 0.5 0)//2
    (24 0.5 0)//3
    (24 -0.5 0)//4
    (0 -0.5 0)//5
    (-0.353553 -0.353553 0)//6
    (-1 0 0)//7
    (-0.707107 0.707107 0)//8
    (0 1 0)//9
    (24 1 0)//10
    (24 -1 0)//11
    (0 -1 0)//12
    (-0.707107 -0.707107 0)//13
    (-8 0 0)//14
    (-8 0.707107 0)//15
    (-8 8 0)//16
    (-0.707107 8 0)//17
    (0 8 0)//18
    (24 8 0)//19
    (24 -8 0)//20
    (0 -8 0)//21
    (-0.707107 -8 0)//22
    (-8 -8 0)//23
    (-8 -0.707107 0)//24-------------
    (-0.5 0 0.1)//25
    (-0.353553 0.353553 0.1)//26
    (0 0.5 0.1)//27
    (24 0.5 0.1)//28
    (24 -0.5 0.1)//29
    (0 -0.5 0.1)//30
    (-0.353553 -0.353553 0.1)//31
    (-1 0 0.1)//32
    (-0.707107 0.707107 0.1)//33
    (0 1 0.1)//34
    (24 1 0.1)//35
    (24 -1 0.1)//36
    (0 -1 0.1)//37
    (-0.707107 -0.707107 0.1)//38
    (-8 0 0.1)//39
    (-8 0.707107 0.1)//40
    (-8 8 0.1)//41
    (-0.707107 8 0.1)//42
    (0 8 0.1)//43
    (24 8 0.1)//44
    (24 -8 0.1)//45
    (0 -8 0.1)//46
    (-0.707107 -8 0.1)//47
    (-8 -8 0.1)//48
    (-8 -0.707107 0.1)//49
  blocks
    hex (7 0 1 8 32 25 26 33) (50 50 1) simpleGrading (1 1 1)//1
    hex (8 1 2 9 33 26 27 34) (50 50 1) simpleGrading (1 1 1)//2
    hex (2 3 10 9 27 28 35 34) (200 50 1) simpleGrading (16469 1 1)//3
    hex (12 11 4 5 37 36 29 30) (200 50 1) simpleGrading (16469 1 1)//4
    hex (13 12 5 6 38 37 30 31) (50 50 1) simpleGrading (1 1 1)//5
    hex (13 6 0 7 38 31 25 32) (50 50 1) simpleGrading (1 1 1)//6
    hex (14 7 8 15 39 32 33 40) (50 50 1) simpleGrading (0.03 1 1)//7
    hex (15 8 17 16 40 33 42 41) (50 80 1) simpleGrading (0.03 20 1)//8
    hex (8 9  18 17 33 34 43 42) (50 80 1) simpleGrading (1 20 1)//9
    hex (9 10 19 18 34 35 44 43) (200 80 1) simpleGrading (16469 20 1)//10
    hex (21 20 11 12 46 45 36 37) (200 50 1) simpleGrading (16469 0.05 1)//11
    hex (22 21 12 13 47 46 37 38) (50 50 1) simpleGrading (1 0.05 1)//12
    hex (23 22 13 24 48 47 38 49) (50 50 1) simpleGrading (0.03 0.05 1)//13
    hex (24 13 7 14 49 38 32 39) (50 50 1) simpleGrading (0.03 1 1)//14
    hex (5 4 3 2 30 29 28 27) (200 200 1) simpleGrading (16469 1 1)//15
  edges
    arc 5 6 (-0.17101 -0.469846 0)
    arc 6 0 (-0.469846 -0.17101 0)
    arc 0 1 (-0.469846 0.17101 0)
    arc 1 2 (-0.17101 0.469846 0)
    arc 9 8 (-0.34202 0.939693 0)
    arc 8 7 (-0.939693 0.34202 0)
    arc 7 13 (-0.939693 -0.34202 0)
    arc 13 12 (-0.34202 -0.939693 0)//----
    arc 30 31 (-0.17101 -0.469846 0.1)
    arc 31 25 (-0.469846 -0.17101 0.1)
        arc 25 26 (-0.469846 0.17101 0.1)
    arc 26 27 (-0.17101 0.469846 0.1)
    arc 34 33 (-0.34202 0.939693 0.1)
    arc 33 32 (-0.939693 0.34202 0.1)
    arc 32 38 (-0.939693 -0.34202 0.1)
    arc 38 37 (-0.34202 -0.939693 0.1)
boundary
 inlet
        type patch;
        faces
    (16 15 40 41)
    (15 14 39 40)
    (14 24 49 39)
    (24 23 48 49)
 outlet
        type patch;
        faces
            (10 19 44 35)
            (3 10 35 28)
            (4 3 28 29)
        (11 4 29 36)
        (20 11 36 45)
 fixedWalls
        type wall;
        faces
    (17 16 41 42)
    (18 17 42 43)
    (19 18 43 44)
    (21 20 45 46)
    (22 21 46 47)
    (23 22 47 48)
    (2 5 30 27)
    (0 1 26 25)
    (1 2 27 26)
    (6 0 25 31)
    (5 6 31 30)
    frontAndBack
        type empty;
        faces
    (20 21 12 11)//b11
    (11 12 5 4)//b4
    (4 5 2 3)//b15
    (3 2 9 10)//b3
    (10 9 18 19)//b10
    (9 8 17 18)//b9
    (8 15 16 17)//b8
    (7 14 15 8)//b7
    (13 24 14 7)//b14
    (22 23 24 13)//b13
    (21 22 13 12)//b12
    (12 13 6 5)//b5
    (13 7 0 6)//b6
    (0 7 8 1)//b1
    (1 8 9 2)//b2-------spiegel
    (46 45 36 37)//b11
    (37 36 29 30)//b4
    (30 29 28 27)//b15
    (27 28 35 34)//b3
    (34 35 44 43)//b10
    (33 34 43 42)//b9
    (40 33 42 41)//b8
    (39 32 33 40)//b7
    (49 38 32 39)//b14
    (48 47 38 49)//b13
    (47 46 37 38)//b12
    (38 37 30 31)//b5
    (38 31 25 32)//b6
    (32 25 26 33)//b1
    (33 26 27 34)//b2
mergePatchPairs
any idea, how to refine the mesh ?
Thx
Mirage12 is offline   Reply With Quote
Old   July 15, 2013, 10:26
colinB is on a distinguished road
well you do some refinement, but in the wrong block.
Be aware that the blocks are counting from 0
so you have 15 blocks but the lowest number is zero
and the highest number is 14
It is the same with the points and the patches as well.
Hint for the future: have look at the whole mesh and see what
it looks like so you can easily figure out what is wrong and do not
only focus in the part that doesn't work, like the picture you displayed.
success
regards
Colin
colinB is offline   Reply With Quote
Old   July 16, 2013, 00:58
Amin
Concerning the numbering of the blocks..you are right i was too lazy to edit it
However capturing the boundary layer is very important for me, that is why i want to refine the mesh close to surface of the geometry....
Any Idea ??
Old   July 16, 2013, 02:53
Hey,
for a good resolution of the boundary layer the y+ value
gives a good indication.
so when you re done with meshing you type
yPlusRAS
in your terminal and check the values which are displayed.
(I assume you are doing a RANS calculation if you
are performing a LES calculation use yPlusLES instead)
dependant on whether you are using wall functions or not
the max values should be between 1 (no wall functions) and
300 (wall functions)
If you know your desired yPlus you can easily calculate the required
cell height with the formula mentioned here:
http://www.cfd-online.com/Wiki/Dimen...e_%28y_plus%29
I hope I could contribute,
regards
Old   July 16, 2013, 03:55
Amin
Hey colin
Thx for ur answer
I am using icoFoam, so i think using a turbulence model is not required.
Do you know how to use yPlus for laminar flow ?
Thx
Old   July 17, 2013, 04:49
Hi
icoFoam is indeed for laminar flow,
so for the boundary layer resolution you should
estimate the thickness of your boundary layer
as described e.g. here:
http://en.wikipedia.org/wiki/Boundary-layer_thickness
in a different forum post it is suggested to have 10 layers
of cells within the viscous layer (see below post #4):
http://www.cfd-online.com/Forums/sta...ary-lowre.html
this should give you a good starting point.
regrads
Old   July 17, 2013, 06:11
Amin
Hello Colin
It is for me clear that #the mesh, close to the surface, should be fine, otherwise it will be hard to converge#.
I estimated the thickness of the boundary layer, and my question is, is there any feature to specify that the mesh should be fine near to surface ?
Thx
[snappyHexMesh] Creating very fine, high accuracy mesh with snappyHexMesh JD_Welch OpenFOAM Meshing & Mesh Conversion 10 July 5, 2023 11:50
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 05:38
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell Arman_N OpenFOAM Meshing & Mesh Conversion 1 May 20, 2019 17:16
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry pizzaspinate OpenFOAM Meshing & Mesh Conversion 1 February 25, 2015 07:05
