[snappyHexMesh] SNappyHexMEsh and GGI (standing mesh gets deleted)
Old   August 22, 2012, 03:21
Exclamation SNappyHexMEsh and GGI (standing mesh gets deleted)
Andreas Wendy
A.Wendy is on a distinguished road
hello,
i have a problem with snappyHexMesh.
i am planing to use GGI to have a rotating Mesh (name: Rotating) and a standing Mesh (name: Umgebung) and created those with one blockMeshdict.
The Surfaces which are in "contact" are: Innenflaeche (from the Standing mesh "Umgebung") and Aussenflache (from the rotating Mesh "Rotating")
When i Run SHM to include a Profile into the Rotating surface my Standing surface gets deleted.
Why is that so? How can i say, that the standing surface should not deleted? Or do i have to use the same Block in BlockMesh for the GGI? I used different blocks for the standing and rotating mesh.
with Regards
Andy
A.Wendy is offline   Reply With Quote
Old   August 2, 2013, 07:04
Klaus
strakakl is on a distinguished road
Hi Andy,
i face the same problem, have you found a solution for this issue?
Best,
Klaus
strakakl is offline   Reply With Quote
[snappyHexMesh] SnappyHexMesh - no layer added bejbro OpenFOAM Meshing & Mesh Conversion 5 February 1, 2020 20:05
