[Commercial meshers] Line 137 BlockMeshDict Problems using ICEM
Old   August 13, 2013, 14:10
Post Line 137 BlockMeshDict Problems using ICEM
Agustin
agval79 is on a distinguished road
Dear all,
I'm new using OpenFOAM. I have been meshing with ICEM for some time, and I want to start using OF for solving my case studies. When I converted my mesh to OpenFOAM and ran blockMesh, I got this message:
Create time
--> FOAM FATAL ERROR:
Cannot open mesh description file
"/home/agustin/OpenFOAM/agustin-2.2.0/run/Fluent/constant/polyMesh/blockMeshDict"
From function blockMesh
in file blockMeshApp.C at line 137.
FOAM exiting
Following the advice of this Forum, I checked the mesh. And apparently is a good one:
Checking geometry...
Overall domain bounding box (-64.5905 -18 -2.4869e-14) (23.0393 180 129.809)
Mesh (non-empty, non-wedge) directions (1 1 1)
Mesh (non-empty) directions (1 1 1)
Boundary openness (6.36975e-15 3.3617e-17 -7.55325e-16) OK.
Max cell openness = 2.71694e-16 OK.
Max aspect ratio = 8.01504 OK.
Minimum face area = 0.417017. Maximum face area = 93.2732. Face area magnitudes OK.
Min volume = 0.750633. Max volume = 282.629. Total volume = 929091. Cell volumes OK.
Mesh non-orthogonality Max: 55.609 average: 7.48596
Non-orthogonality check OK.
Face pyramids OK.
Max skewness = 1.5071 OK.
Coupled point location match (average 0) OK.
Mesh OK.
End
Tried blockMesh again with the same result. Then I ran another mesh that a friend helped me to create using Snappy. This mesh works very well. However, I want to do my own meshes using ICEM. Do you have a clue of what is going on?
Thanks.
agval79 is offline   Reply With Quote
Old   August 14, 2013, 01:22
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
blockMesh or snappyHexMesh are mesher. So if you already have your mesh with ICEM, why do you want to re-create one?
You only need to import your ICEM-mesh
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   August 14, 2013, 04:14
Red face
Agustin
Thank you very much -mAx-. It's working very well now. I had the impression from the tutorials that blockMesh was always required previous to any running to UPLOAD the geometry in paraFoam. Thanks.
[mesh manipulation] RefineMesh Error and Foam warning jiahui_93 OpenFOAM Meshing & Mesh Conversion 4 March 3, 2018 11:32
[mesh manipulation] refineMesh Error mohsen.boojari OpenFOAM Meshing & Mesh Conversion 3 March 1, 2018 22:07
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 keepfit ParaView 60 September 18, 2013 03:23
is internalField(U) equivalent to zeroGradient? immortality OpenFOAM Running, Solving & CFD 7 March 29, 2013 01:27
Problems of Duns Codes! Martin J Main CFD Forum 8 August 14, 2003 23:19
