[Gmsh] Generating multiple internal walls using gmshToFoam
Old   September 30, 2013, 10:40
Default Generating multiple internal walls using gmshToFoam
rendagar is on a distinguished road
Hello fellow CFD enthusiasts,
I've been banging my head against a problem for a couple of days now and am hoping someone can help me.
First let me give you an idea of what I would like to simulate. The basic idea is a simple rectangular box with 2 separate fans inside, not connected to the wall. To start with I would like to solve the (incompressible) flow inside the box at different fan speeds.
The problem I have is that when I generate a mesh file using
gmsh which has internal geometries (i.e. the fans) they are lost after I convert the file using the gmshToFoam tool. I have read a couple of (older) posts about this problem however the solutions they post only work for converting a single boundary, which is not enough.
This old post comes close to that I require.
http://www.cfd-online.com/Forums/ope...-openfoam.html. It instructs you to make a number of changes to the boundary file and files in 0/ and to repeat this process for all patches. I can make the process work once but than all information regarding the not yet converted internal patches is lost and the face indexes are recalculated, so I can't add them. A possible cause is that I am missing the faceSet command however I have been unable to locate the command or that it is supposed to do. All my tries so far have been with the .geo file provided in the post above and have been unsuccessfully (for multiple patches, a single patch is no problem).
This post
http://www.cfd-online.com/Forums/ope...tml#post323464 is a bit more recent but describes the same process and also fails on multiple faces.
A possible solution (found in
http://openfoamwiki.net/index.php/Ho...internal_walls) would be http://openfoamwiki.net/index.php/Co...itMeshWithSets however I don't know how to compile this. I have extracted the file to /opt/OpenFOAM-2.2.1/applications/utilities/mesh/manipulation and tried to use wmake to compile it. However when I try to use wmake it complains that the environment variable $WM_OPTIONS is not set. I believe that is incorrect because ">>echo $WM_OPTIONS" returns "linux64GccDPOpt". I don't know it that is correct but WM_OPTIONS is certainly is set to something.
If anyone solved this problem, knows of a better approach to generating a mesh with internal structures (using non commercial software) or what the problem with wmake is, I would very much appreciate your input.
Regards,
rendagar is offline   Reply With Quote
Old   October 13, 2014, 02:20
Adrien Cahuzac
acahuzac is on a distinguished road
Same issu in OpenFoam 2.3.0. Please, some help ?
acahuzac is offline   Reply With Quote
Old   October 20, 2014, 03:56
Adrien Cahuzac
The only solution I found, and which works quite well, is to make distinct meshes with Gmsh, and then merge them with "mergeMeshes". A bit tedious, but at least it works fine.
gmsh, gmshtofoam, internal face, internal wall, wmake
[blockMesh] Internal walls of zero thickness anger OpenFOAM Meshing & Mesh Conversion 23 February 6, 2020 18:25
Multiple internal fields boundary conditions manu551 OpenFOAM Running, Solving & CFD 0 January 4, 2017 10:00
ParaView and Qt 4.3.5 on Mac OS X 10.6 Adrian OpenFOAM 3 August 8, 2010 03:16
[snappyHexMesh] SnappyHexMesh internal walls podallaire OpenFOAM Meshing & Mesh Conversion 2 July 24, 2008 09:12
Internal Walls in Hex hagupta CFX 4 June 7, 2006 09:09
