[Commercial meshers] Hypermesh Update????
Old   January 26, 2012, 09:10
Default Hypermesh Update????
n/a
deji is on a distinguished road
Hello Foamers. I am in the process of creating my 3D meshes with hypermesh, and need to know if there is any update regarding converting these hypermesh files into OpenFOAM? I did see a couple of threads regarding this same topic, but they are quite old. Can anyone please give me some feedback on this?
Cheers,
Deji
deji is offline   Reply With Quote
Old   January 26, 2012, 09:13
n/a
I think I've found the answer to my question,
Deji
Old   January 30, 2012, 04:26
BastiL
bastil is on a distinguished road
Deji
And what is the answer, please?
bastil is offline   Reply With Quote
Old   January 30, 2012, 07:47
Slawek
slawekchr is on a distinguished road
you can export your mesh from Hypermesh directly to OpenFoam
(it is possible from Hypermesh version 10.0).
Or you can export from HM to fluent and then use fluentMeshToFoam.
Slawek
slawekchr is offline   Reply With Quote
Old   May 3, 2013, 07:51
Rishi .
hellorishi is on a distinguished road
Although there is a direct way to export from HyperMesh to OpenFOAM, exporting via Fluent remains the most robust method (as of HyperMesh 12.0).
hellorishi is offline   Reply With Quote
Old   May 3, 2013, 08:14
Daniel Pielmeier
billie is on a distinguished road
Currently exporting to fluent mesh is the more robust method as hellorishi already mentioned.
This is especially true for multi-region cases and if internal faces are required which is because the direct export from Hypermesh to Openfoam does not distinguish between internal and external faces. Everything is exported as a boundary. Exporting to fluent format first and using fluent*MeshToFoam creates boundaries for external faces and faceZones for internal faces if the recommended naming scheme is used in Hypermesh (i. e. prefixing internal faces with inte_).
There are also some face ordering problems which can occur when using the direct export method. This however can be fixed by using renumberMesh.
I have reported this issues to Altair and maybe this will be fixed eventually.
billie is offline   Reply With Quote
Old   May 14, 2013, 07:08
Daniel Pielmeier
Today I received an email from the Altair support. The issues I have reported will be fixed in the next Update which will be Hyperworks 12.0-110. Lets see if this improves direct export to OpenFOAM from Hyperworks.
Old   October 3, 2013, 04:45
Daniel Pielmeier
The Hyperworks 12.0 SA Update which includes Hypermesh 12.0.110.40 fixes the above mentioned issues. Direct export to OpenFOAM significantly improved with this version.
Change "Implicit Mesh Update Interval" using UDF ASimonsen Fluent UDF and Scheme Programming 2 October 12, 2017 09:38
libsampling for DyM solver exporting vtk patch. Problem to update geometry be_inspired OpenFOAM Post-Processing 3 October 9, 2015 07:58
Using Workbench, CFX-Pre doesn't update mesh from upstream data Shawn_A CFX 2 November 25, 2012 13:06
Hypermesh Exporting eishinsnsayshin ANSYS 0 April 3, 2012 18:16
Hypermesh file to Fluent Logesh FLUENT 1 November 30, 2011 13:46
