[blockMesh] blockMesh | MergePatchPairs | snappyHexMesh |Different number of cells in divisions
Old   October 25, 2013, 11:49
Default blockMesh | MergePatchPairs | snappyHexMesh |Different number of cells in divisions
pythag0ra5 is on a distinguished road
Hi there,
i have a question concerning blockMesh, especcially the mergePatchPair-section. I would like to create 2 blocks (block I and block II) as you can see in the image below. One can see, that these blocks should have different numbers of cells in the y-direction.
If i run blockMesh, i receive my desired mesh. But if i run snappyHexMesh afterwards, i receive an error like:
--> FOAM FATAL ERROR:
cell 934000 of level 0 uses more than 8 points of equal or lower level
Points so far:8(473280 473470 473660 511470 511660 511850 985911 985971)
If i modify the blocks in blockMesh so that block I and II has the same number in the y-direction, either blockMesh and snappyHexMesh produces a mesh.
Do you have any hints for me in order to obtain my desired mesh (in snappyHexMesh)?
Best regards!
pythag0ra5 is offline   Reply With Quote
Old   September 19, 2020, 14:38
HosseinB is on a distinguished road
I am having the same issue. Did you find an answer to this?
Thanks
HosseinB is offline   Reply With Quote
blockmesh, mergepatchpairs, snappyhexmesh
[snappyHexMesh] sHM layer process keeps getting killed MBttR OpenFOAM Meshing & Mesh Conversion 4 August 15, 2016 03:21
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
Compressor Simulation using rhoPimpleDyMFoam Jetfire OpenFOAM Running, Solving & CFD 107 December 9, 2014 13:38
killed "snappyHexMesh" parkh32 OpenFOAM Pre-Processing 2 April 8, 2012 17:12
[snappyHexMesh] snappyHexMesh aborting Tobi OpenFOAM Meshing & Mesh Conversion 0 November 10, 2010 03:23
