[snappyHexMesh] nCellsBetweenLevels
Old   November 16, 2013, 11:09
Default nCellsBetweenLevels
Eloïse
Eloise is on a distinguished road
I'm experiencing a problem with the parameter nCellsBetweenLevels.
I was first using nCellsBetweenLevels 2 for a given mesh. I needed to increase it to nCellsBetweenLevels 3 and I obtained a mesh with less cells than in the first mesh.
The first thing I checked is the maximum number of cells allowed in sHM. There is no problem on that side, the limit is much higher than the mesh size.
I then looked into the log from sHM. The castellation step is split in 4 stages:
1. Feature edges refinement
2. Surface refinement
3. Cell removal inside the body
4. Shell refinement
I compared the number of cells at the end of each stage and the difference appears at the beginning of the "Shell refinement" stage where the number of cells selected for internal refinement is lower in the second mesh than in the first mesh (while it should be the opposite!).
Has anyone already experienced something similar? Do you have an idea what this is due to?
I appreciate your help!
Eloïse
Mesh 1 (with nCellsBetweenLevels 2):
Shell refinement iteration 0
Marked for refinement due to refinement shells    : 65967 cells.
Determined cells to refine in = 4.65 s
Selected for internal refinement : 983327 cells (out of 6561575)
Edge intersection testing:
    Number of edges             : 44510076
    Number of edges to retest   : 39665421
    Number of intersected edges : 3887457
Refined mesh in = 9.16 s
After refinement shell refinement iteration 0 : cells:13444864  faces:44510076  points:17659672
Mesh 2 (with nCellsBetweenLevels 3):
Determined cells to refine in = 3.74 s
Selected for internal refinement : 74967 cells (out of 6561575)
    Number of edges             : 24200235
    Number of edges to retest   : 2389770
    Number of intersected edges : 2975683
Refined mesh in = 4.2 s
After refinement shell refinement iteration 0 : cells:7086344  faces:24200235  points:10165443
Eloise is offline   Reply With Quote
[cfMesh] Refinement diffusion or in snappy-variables: nCellsBetweenLevels schiffbauer OpenFOAM Community Contributions 2 February 16, 2020 17:37
[snappyHexMesh] SnappyHexMesh Refinement nCellsBetweenLevels laymelek OpenFOAM Meshing & Mesh Conversion 13 December 22, 2018 16:33
[snappyHexMesh] nCellsBetweenLevels problem laurent98 OpenFOAM Meshing & Mesh Conversion 2 April 11, 2013 19:51
SnappyHexMesh nCellsBetweenLevels 3 wikstrom OpenFOAM Bugs 3 November 13, 2008 11:08
