[mesh manipulation] Create mesh by mirroring / translating an existing mesh
Old   November 18, 2013, 08:26
Default Create mesh by mirroring / translating an existing mesh
pythag0ra5 is on a distinguished road
Dear all,
i want to simulate the flow through a system consisnting of two sveral pipes. Therefore, i created a mesh of a small part of the geometry with ICEM. For pictures, please see this tread:
http://www.cfd-online.com/Forums/ans...cate-mesh.html
Within my research, i found a tool in OpenFOAM called mirrorMesh, which seems to be suitable for answering my question. If i understand it correctly, mirrorMesh just mirrors the mesh, therfore i need to different folders for the original (non-mirrored) and the mirrored-mesh. After this, i think have to use mergeMesh in order to merge the two meshes.
Is this procedure correct or is there any procedure which is able to mirror the mesh and removing duplicate surfaces at the same time? Do you have any smarter solution?
Thanks in advance!
pythag0ra5 is offline   Reply With Quote
mirrormesh, transformpoints
[snappyHexMesh] Creating multiple multiple cell zones with snappyHexMesh - a newbie in deep water! divergence OpenFOAM Meshing & Mesh Conversion 0 January 23, 2019 04:17
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 06:21
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 04:24
[mesh manipulation] polyDualMesh, create a tetrahedral mesh from a polyhedral mesh Martin80 OpenFOAM Meshing & Mesh Conversion 5 January 30, 2013 22:07
[blockMesh] Include list of points Hikachu OpenFOAM Meshing & Mesh Conversion 0 June 20, 2011 09:03
