[Technical] What is surfMEsh?
Old   September 1, 2021, 14:41
Default What is surfMEsh?
Mandeep Shetty
granzer is on a distinguished road
The utility 'surfaceMeshExport' exports from "surfMesh"
surfaceMeshExport
Export from surfMesh to various third-party surface formats with optional scaling or transformations (rotate/translate) on a coordinateSystem
What is surfMesh?.
When I try to run the SurfaceMeshExport to export to a .nas format command I get an error stating
Cannot find file "faces" in directory "surfaces/default/surfMesh" in times "0" down to constant
I have 'polymesh" directory containing the mesh. Where is "surfaces/default/surfMesh"?
Thank you.
granzer is offline   Reply With Quote
Old   September 2, 2021, 23:28
Mandeep Shetty
Hello ..I am still looking for a clear answer. I suspect surfMesh is similar to polyMesh but I still haven't found where it is used ie the surfaces/default/surfMesh. Can someone please help me out?
utility
surfMesh, surfaceMesh, meshedSurface? frobaux OpenFOAM Programming & Development 4 February 24, 2020 06:15
[OpenFOAM] surfMesh not support with paraview? su_junwei ParaView 1 April 6, 2010 11:08
