[Other] Creating Mesh for double body
Old   February 17, 2014, 16:16
Default Creating Mesh for double body
Tobias W.
tw002 is on a distinguished road
Hello, I'm new at OF and I'm trying to create a mesh for double body flow. The problem is I've got a stl-file with two solids. Once the solid for the submerged part of the ship and on the other hand the solid for the area above the waterline. For double body flow I only need the submerged solid, Creating a symmetry plane at waterline area to avoid influence of the free surface. Is it possible to create a block mesh that only depends on the draught?
Happy if you could help me.
tw002 is offline   Reply With Quote
[mesh manipulation] How to write cellSet for different regions in constant/polyMesh/sets Struggle_Achieve OpenFOAM Meshing & Mesh Conversion 3 June 17, 2019 09:29
Star CCM Overset Mesh Error (Rotating Turbine) thezack Siemens 7 October 12, 2016 11:14
[snappyHexMesh] dynamic mesh: rotating body with increasing/decreasing distance to fixed body mo_na OpenFOAM Meshing & Mesh Conversion 3 July 26, 2016 04:51
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 04:24
