[blockMesh] A Foam Warning on "libsimpleSwakFunctionObjects.so" in blockMesh command
Like Tree1Likes
  • 1 Post By gschaider
Old   January 31, 2014, 01:32
Default A Foam Warning on "libsimpleSwakFunctionObjects.so" in blockMesh command
immortality's Avatar
Ehsan
immortality is on a distinguished road
why its complaining about a SWAK file after I run the command blockMesh?
Create time
--> FOAM Warning :
    From function dlOpen(const fileName&, const bool)
    in file POSIX.C at line 1179
    dlopen error : libsimpleSwakFunctionObjects.so: cannot open shared object file: No such file or directory
--> FOAM Warning :
    From function dlLibraryTable::open(const fileName&, const bool)
    in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 99
    could not load "libsimpleSwakFunctionObjects.so"
--> FOAM Warning :
    dlopen error : libswakFunctionObjects.so: cannot open shared object file: No such file or directory
--> FOAM Warning :
    could not load "libswakFunctionObjects.so"
Creating block mesh from
    "/home/ehsan/Desktop/high-Re_Grid_independence/turbulent_hR700$54/constant/polyMesh/blockMeshDict"
Creating curved edges
Creating topology blocks
Creating topology patches
Creating block mesh topology
Check topology
	Basic statistics
		Number of internal faces : 4
		Number of boundary faces : 16
		Number of defined boundary faces : 16
		Number of undefined boundary faces : 0
	Checking patch -> block consistency
Creating block offsets
Creating merge list .
Creating polyMesh from blockMesh
Creating patches
Creating cells
Creating points with scale 1
Writing polyMesh
Mesh Information
  boundingBox: (0 0 0) (0.069 0.004 0.001)
  nPoints: 77110
  nCells: 37800
  nFaces: 151954
  nInternalFaces: 74846
Patches
  patch 0 (start: 74846 size: 54) name: right
  patch 1 (start: 74900 size: 54) name: left
  patch 2 (start: 74954 size: 1400) name: walls
  patch 3 (start: 76354 size: 75600) name: empty_faces
End
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
immortality is offline   Reply With Quote
Old   January 31, 2014, 05:24
Assistant Moderator
Bernhard Gschaider
Create time
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
Check topology
	Basic statistics
Creating patches
Creating cells
Writing polyMesh
Mesh Information
  nPoints: 77110
  nCells: 37800
  nFaces: 151954
Patches
End
You probably got it in the libs-entry in controlDict and then OF tries to load the libraries there
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   January 31, 2014, 08:33
Ehsan
Dear Bernhard,its in controlDict,then the error is about not using it in the run?
Old   January 31, 2014, 18:55
Assistant Moderator
Bernhard Gschaider
Yeah.
But it's only a warning
immortality likes this.
[snappyHexMesh] How to define to right point for locationInMesh Mirage12 OpenFOAM Meshing & Mesh Conversion 7 March 13, 2016 14:07
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 09:56
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 08:48
Can anybody help me to solve the list errors while compiling Openfoam 15 on Opensuse 103 32bit coompressor OpenFOAM Installation 0 November 12, 2008 19:53
OpenFOAM14 for Mac OSX Darwin 104 gschaider OpenFOAM Installation 118 July 20, 2008 05:19
