[mesh manipulation] extrudeMesh index error
Old   February 17, 2014, 20:38
Default extrudeMesh index error
A. Craig
craig0a is on a distinguished road
Hello everyone,
I have been following the excellent tutorial for going from points->stl->snappyHex->extrudeMesh for a 2D geometry as given here https://www.dropbox.com/s/jibjooemkg8makz/memory.pdf with code available here https://www.dropbox.com/s/tihb4d943e23xdu/gearMain.zip (I also just completed trying the wingmotion tutorial with identical results.)
So far, I have just been running the unmodified code. I have followed the instructions to the letter, with the one exception that I did not do parallel computing. Unfortunately, there is something wrong: after running snappyHexMesh and flattenMesh but attempting to run extrudeMesh comes back with the error
--> FOAM FATAL ERROR:
index -1 out of range 0 ... 0
From function UList<T>::checkIndex(const label)
in file /share/apps/me469/openfoam/2.2.2/OpenFOAM-2.2.2/src/OpenFOAM/lnInclude/UListI.H at line 109.
FOAM aborting
To me, this is looking like something to do newer OpenFoam versions being backwards incompatible, but I am hoping that is not the case. I haven't been able to find anything about this error on the threads, but I apologize if I missed the answer somewhere.
If anyone has suggestions as to what might be causing this error or how I can track it down more thoroughly, I would be very grateful.
Thank you!
Best,
A. Craig
craig0a is offline   Reply With Quote
error, extrudemesh, openfoam, snappyhexmesh
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 19:43
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
[OpenFOAM] Paraview 3.98 - errors when saving geometry file pajot ParaView 1 September 28, 2013 10:45
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 02:32
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
