[snappyHexMesh] Shell Refinement running for 99 iterations |
February 28, 2014, 13:34 |
Paul McClafferty
Rep Power: 12 |
Sorry if this is a stupid question, but I was wondering if anyone could tell me what part of my snappyHexMeshDict is causing this to run for so long? I have tried changing some of it but have no luck reducing the time snappyHexMesh takes to run. Thanks very much
February 28, 2014, 14:05 |
Paul McClafferty
Rep Power: 12 |
it also took just over an hour simply to run snappyHexMesh, any advice for a newcomer would be greatly appreciated
March 1, 2014, 10:04 |
Julian Langowski
Rep Power: 15 |
Dear Paul,
would be helpful to see your SnappyDict and the log as Code:
Code. minRefinementCells you are looking for. Best regards Julian
πάντα ῥεῖ - Heraclitus |
March 1, 2014, 12:49 |
#4 | |
Paul McClafferty
Rep Power: 12 |
Thanks for the response. I have tried changing that to 5, and then 0 but it still runs for a long time. here is the snappyHexMeshDict file
Thanks for your help |
March 1, 2014, 13:12 |
#5 | |
Paul McClafferty
Rep Power: 12 |
with that shmd i am getting the following error
Thanks again |
March 1, 2014, 13:23 |
#6 | |
Julian Langowski
Rep Power: 15 |
Dear Paul,
concerning faster snapping: Try increasing minRefinementCells. Snappy tries to refine the mesh, until the defined number of cells still to refine is reached. Thus it stops earlier, if you increase the value. The other thing: Check the error message: Quote:
Best regards Julian
March 20, 2015, 10:05 |
Paul McClafferty
Rep Power: 12 |
Yes it is solved thanks anyway
August 13, 2017, 18:26 |
#9 |
Moe Alams
Rep Power: 9 |
Yes Tobi please give suggestions. I am dealing with a similar issue.
Thank you! |
December 22, 2017, 05:49 |
#10 |
Rep Power: 8 |
Hi guys,
I also experienced this recently. Sometimes it takes just 2 iterations for shell refinement of 2 Million cells and sometimes 90 iterations for the same number cells to refine. Could anyone enlighten the reason behind this/ significance of this? Regards, Rajan |
February 25, 2020, 14:19 |
#11 |
Tobias Holzmann
Rep Power: 51 |
It is based on the refinement level one sets up. E.g.;
level (1 3) This will refine your patch by level one in any case. However, based on the featureAngle you will refine e.g., some cells. Based on the new refinements it might occur that new cells are now selected to be refined (based on the refinement done previously). Thus, one can run into a refinement loop that does not stop. One example in which I observed that stuff. I did a refinement of (1 2) on a roof. The roof was aligned in such a way in accordance with the featureAngle that only a few cells gets selected for each surface refinement. After the refinement was done, the neighbor cells got selected to be refined until the whole roof was refined by level two. To overcome this there are more options:
Furthermore, as also mentioned by the CEO from cfMesh, the surface triangulation is important; c.f. Creating waterproof STL using snappyHexMesh or salome
Keep foaming, Tobias Holzmann |
pimpleDyMFoam computation randomly stops | babapeti | OpenFOAM Running, Solving & CFD | 5 | January 24, 2018 05:28 |
chtMultiRegionSimpleFoam turbulent case | Aditya Patil | OpenFOAM Running, Solving & CFD | 6 | April 24, 2017 22:13 |
High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 13:40 |
Cannot run the code properly: very large time step continuity error | crst15 | OpenFOAM Running, Solving & CFD | 9 | December 14, 2014 18:17 |
pimpleFoam: turbulence->correct(); is not executed when using residualControl | hfs | OpenFOAM Running, Solving & CFD | 3 | October 29, 2013 08:35 |
