[snappyHexMesh] castelatedMesh failure
Old   March 17, 2014, 12:17
Default castelatedMesh failure
Heremus is on a distinguished road
I am new to CFD and openFOAM I am actually trying to set up my first case. But have already problems in Meshingprocess. I googled so far but didn't find an answer jet. Maybe i didn't found the right keywords...
I tried to generate a Mesh after this tutorial:
http://www.hydroniumion.de/posts/sna...mesh-tutorial/
SHM gives out following errormessage:
|  \\    /   O peration     | Version:  2.2.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 2.2.0-5be49240882f
Exec   : snappyHexMesh
Date   : Mar 17 2014
Time   : 17:37:02
Host   : "Laptop-V1S"
PID    : 30436
Case   : /home/tofu/OpenFOAM/Test/strgb3
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create mesh for time = 0
Read mesh in = 0.16 s
Overall mesh bounding box  : (-20 0 -9.012) (6 5 10.988)
Relative tolerance         : 1e-06
Absolute matching distance : 3.31813e-05
Reading refinement surfaces.
Read refinement surfaces in = 0.75 s
Reading refinement shells.
Refinement level according to distance to hull.stl
    level 5 for all cells within 0.1 meter.
    level 4 for all cells within 0.4 meter.
    level 2 for all cells within 1 meter.
Read refinement shells in = 0 s
Setting refinement level of surface to be consistent with shells.
Checked shell refinement in = 0 s
Reading features.
--> FOAM FATAL IO ERROR:
keyword features is undefined in dictionary "/home/tofu/OpenFOAM/Test/strgb3/system/snappyHexMeshDict.castellatedMeshControls"
file: /home/tofu/OpenFOAM/Test/strgb3/system/snappyHexMeshDict.castellatedMeshControls from line 37 to line 72.
    From function dictionary::lookupEntry(const word&, bool, bool) const
    in file db/dictionary/dictionary.C at line 402.
FOAM exiting
My snappyHexMeshDict:
FoamFile
        version 2.0;
        format ascii;
        root "";
        case "";
        instance "";
        local "";
        class dictionary;
        object autoHexMeshDict;
// Which of the steps to run
castellatedMesh true;
snap            true;
addLayers       true;
geometry
     hull.stl
         type triSurfaceMesh;
         name DIFUSOR;
    maxLocalCells 10000000;
    maxGlobalCells 20000000;
    minRefinementCells 0;
    nCellsBetweenLevels 1;
    refinementSurfaces
       DIFUSOR
        level (4 5);
    resolveFeatureAngle 30;
    // Region-wise refinement
    refinementRegions
    DIFUSOR
        mode distance;
        levels ((0.1 5) (0.4 4) (1 2));
    // Mesh selection
    locationInMesh (6.011 8.012 3.01);
    allowFreeStandingZoneFaces true;
// Settings for the snapping.
snapControls
    nSmoothPatch 3;
    tolerance 2.0;
    nSolveIter 30;
    nRelaxIter 5;
        nFeatureSnapIter 10;
        implicitFeatureSnap true;
        explicitFeatureSnap false;
// Settings for the layer addition.
addLayersControls
layers
    hull.stl_hulls
        nSuraceLayers 12;
expansionRatio 1.2;
minThickness 0.0005;
meshQualityControls
// Advanced
// Flags for optional output
// 0 : only write final meshes
// 1 : write intermediate meshes
// 2 : write volScalarField with cellLevel for postprocessing
// 4 : write current intersections as .obj files
// debug 0;
// Merge tolerance. Is fraction of overall bounding box of initial mesh.
// Note: the write tolerance needs to be higher than this.
mergeTolerance 1e-6;
After this error Message I can't find the word features. Or did I set some wrong Properties?
I also don't understand the command locationInMesh.
Thanks for any help!
Heremus is offline   Reply With Quote
Old   March 19, 2014, 10:53
cutter is on a distinguished road
have a look at http://www.openfoam.org/docs/user/snappyHexMesh.php (Section 5.4.3) and one of the tutorial cases to learn the correct usage of the subdictionary 'features'.
'locationInMesh' is a point within your fluid domain. It allows snappyHexMesh to decide whether to mesh inside or outside the STL surface. See section 5.4.4!
Cutter
cutter is offline   Reply With Quote
castellated, mesh, snappyh
Error running openfoam in parallel fede32 OpenFOAM Programming & Development 5 October 4, 2018 16:38
P1 and DT Radiation Model Failure Birnensuppe CFX 6 November 13, 2017 06:06
The fluent stopped and errors with "Warning: License server connection lost.poll: pro yuyuxuan FLUENT 4 January 9, 2014 05:20
NEW failure to compile redistributeMeshPar pasinari OpenFOAM Bugs 2 December 31, 2007 04:56
what is zero face area failure?? DON Siemens 5 June 1, 2007 01:09
