[Technical] checkMesh states mesh is OK yet faces are bent pentagons
Old   March 20, 2014, 04:40
Default checkMesh states mesh is OK yet faces are bent pentagons
Richel Bilderbeek
assert is on a distinguished road
My question is: how can this mesh be correct (and how can the original mesh be incorrect)?
This is a follow-up of http://www.cfd-online.com/Forums/ope...s-correct.html , where I had a AFAIKS correct mesh, yet checkMesh gave two errors.
On that mesh I did the following commands:
renumberMesh
zipUpMesh
This resulted in a 'correct' (that is: according to checkMesh) mesh, with six faces, two of which are bent polygons. The image below shows the point indices, the others show the face indices. Of the bent polygon faces, I number the vertex indices.
How can this mesh be correct (and how can the original mesh be incorrect)?
Below I put the content of the AFAIK most important files, you can view all at http://www.richelbilderbeek.nl/ToolO...dCorrected.htm .
checkMesh output (I removed some text, indicated with [...]):
Build  : 2.1-88b2f2ae3a0b
Exec   : checkmesh
Date   : Mar 20 2014
Time   : 08:03:54
Host   : "AIRBEAR-W7-I5"
PID    : 2764
Case   : D:/Projects/Test/ToolOpenFoamErrorOpenCellsFoundCorrected
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create polyMesh for time = 0
Time = 1
Mesh stats
    internal points:  0
    faces:            8
    internal faces:   0
    cells:            2
    boundary patches: 6
    point zones:      0
    face zones:       0
    cell zones:       0
Overall number of cells of each type:
    hexahedra:     0
    prisms:        0
    wedges:        0
    pyramids:      0
    tet wedges:    0
    tetrahedra:    0
    polyhedra:     2
Checking topology...
    Boundary definition OK.
    Cell to face addressing OK.
    Point usage OK.
    Upper triangular ordering OK.
    Face vertices OK.
   *Number of regions: 2
    The mesh has multiple regions which are not connected by any face.
  <<Writing region information to "1/cellToRegion"
Checking patch topology for multiply connected surfaces ...
    Patch               Faces    Points   Surface topology
    back                1        4        ok (non-closed singly connected)
    bottom              2        4        ok (non-closed singly connected)
    front               1        4        ok (non-closed singly connected)
    left                1        4        ok (non-closed singly connected)
    right               1        4        ok (non-closed singly connected)
    top                 2        6        ok (non-closed singly connected)
Checking geometry...
    Overall domain bounding box (-1 -1 0) (1 1 1)
    Mesh (non-empty, non-wedge) directions (1 1 1)
    Mesh (non-empty) directions (1 1 1)
    Boundary openness (-2.28837e-018 -1.83069e-017 0) OK.
    Max cell openness = 5.55112e-017 OK.
    Max aspect ratio = 2 OK.
    Minimum face area = 1. Maximum face area = 2.23607.  Face area magnitudes OK.
    Min volume = 0.731939. Max volume = 0.731939.  Total volume = 1.46388.  Cell volumes OK.
    Non-orthogonality check OK.
    Face pyramids OK.
    Max skewness = 0.34936 OK.
    Coupled point location match (average 0) OK.
Mesh OK.
End
points, as shown at the top-left of the image:
FoamFile
    version     2.0;
    format      ascii;
    class       vectorField;
    location    "1/polyMesh";
    object      points;
8((0 1 1) (-1 0 1) (0 1 0) (0 -1 1) (1 0 0) (0 -1 0) (-1 0 0) (1 0 1))
faces, as shown in the image:
FoamFile
    version     2.0;
    format      ascii;
    class       faceList;
    object      faces;
8
4(0 2 6 1)
3(5 6 4)
3(4 6 2)
4(1 6 5 3)
4(4 7 3 5)
4(0 7 4 2)
5(3 7 4 6 1)
5(1 6 4 7 0)
boundaries:
FoamFile
    version     2.0;
    format      ascii;
    class       polyBoundaryMesh;
    object      boundary;
6
    back
        type            zeroGradient;
        nFaces          1;
        startFace       0;
    bottom
        type            zeroGradient;
        nFaces          2;
        startFace       1;
    front
        type            zeroGradient;
        nFaces          1;
        startFace       3;
    left
        type            zeroGradient;
        nFaces          1;
        startFace       4;
    right
        type            zeroGradient;
        nFaces          1;
        startFace       5;
    top
        type            zeroGradient;
        nFaces          2;
        startFace       6;
owner:
FoamFile
    version     2.0;
    format      ascii;
    class       labelList;
    note        "nPoints:8  nCells:2  nFaces:8  nInternalFaces:0";
    object      owner;
8(1 0 1 0 0 1 0 1)
neighbour:
FoamFile
    version     2.0;
    format      ascii;
    class       labelList;
    object      neighbour;
0()
Again, all and complete files are at http://www.richelbilderbeek.nl/ToolO...dCorrected.htm
assert is offline   Reply With Quote
Old   March 24, 2014, 09:10
Default Solved
Richel Bilderbeek
The source error http://www.cfd-online.com/Forums/ope...s-correct.html has been solved and the answer can be found there.
I will never accept a 'Friend' request, I will always accept beer
bent face, checkmesh, mesh, pentagon, renumbermesh
[Gmsh] Vertex numbering is dense KateEisenhower OpenFOAM Meshing & Mesh Conversion 7 August 3, 2015 10:49
snappyhexmesh remove blockmesh geometry philipp1 OpenFOAM Running, Solving & CFD 2 December 12, 2014 10:58
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem Attesz OpenFOAM Meshing & Mesh Conversion 12 May 2, 2013 10:52
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
