[Salome] idearToFoam problem
Old   September 8, 2014, 10:30
Default idearToFoam problem
felicemastronzo's Avatar
Felice
felicemastronzo is on a distinguished road
Dear all,
I have created a mesh in Salome that is basically made by 3 boundaries called "l", "v" and "c".
When I try to convert the mesh into the OF format I get following...
Processing tag:2420
Skipping tag 2420 on line 9
Skipping section at line 9.
Processing tag:2411
Starting reading points at line 20.
Read 26996 points.
Processing tag:2412
Starting reading cells at line 54015.
First occurrence of element type 11 for cell 1 at line 54016
First occurrence of element type 41 for cell 23352 at line 124069
First occurrence of element type 111 for cell 71136 at line 219637
Read 92563 cells and 47784 boundary faces.
Processing tag:2467
Starting reading patches at line 404765.
For group 1 named v trying to read 4181 patch face indices.
For group 4 named c trying to read 23562 patch face indices.
For group 5 named l trying to read 20778 patch face indices.
Sorting boundary faces according to group (patch)
0: v is patch
1: c is patch
2: l is faceZone
Constructing mesh with non-default patches of size:
v 4181
c 23562
--> FOAM Warning :
From function polyMesh:olyMesh(... construct from shapes...)
in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 627
Found 20041 undefined faces in mesh; adding to default patch.
Adding cell and face zones
Face Zone l 20778
ideasUnvToFoam: ideasUnvToFoam.C:1273: int main(int, char**): Assertion `noveau > -1' failed.
First of all "l" should be a patch like the other, why it appears like a faceZone? If I eliminate that boundary the conversion works except, off course for a warning
--> FOAM Warning :
End
Regards
PS: attatched mehs
felicemastronzo is offline   Reply With Quote
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
