[blockMesh] blockMesh how to set internal face ?
Old   April 5, 2014, 06:22
Default blockMesh how to set internal face ?
seav is on a distinguished road
Hello, I have problem with my case. I wrote vertices and hexes and when I am trying to make faces I got alot of errors.
I want to make a small cube inside bigger one. The small cube is a plate and its not moving so I singed wall type.
[root@archlinux:random]# paraFoam -block
created temporary 'random.blockMesh'
Creating block mesh topology
--> FOAM FATAL ERROR:
Trying to specify a boundary face 4(21 25 41 37) on the face on cell 10 which is either an internal face or already belongs to some other patch.  This is face 0 of patch 0 named plate.
    From function polyMesh::setTopology
    const cellShapeList& cellsAsShapes,
    const faceListList& boundaryFaces,
    const wordList& boundaryPatchNames,
    labelList& patchSizes,
    labelList& patchStarts,
    label& defaultPatchStart,
    label& nFaces,
    cellList& cells
    in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 360.
FOAM aborting
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::error::abort() at ??:?
#2  Foam::polyMesh::setTopology(Foam::List<Foam::cellShape> const&, Foam::List<Foam::List<Foam::face> > const&, Foam::List<Foam::word> const&, Foam::List<int>&, Foam::List<int>&, int&, int&, Foam::List<Foam::cell>&) at ??:?
#3  Foam::polyMesh::polyMesh(Foam::IOobject const&, Foam::Xfer<Foam::Field<Foam::Vector<double> > > const&, Foam::List<Foam::cellShape> const&, Foam::List<Foam::List<Foam::face> > const&, Foam::List<Foam::word> const&, Foam::PtrList<Foam::dictionary> const&, Foam::word const&, Foam::word const&, bool) at ??:?
#4  Foam::blockMesh::createTopology(Foam::IOdictionary const&, Foam::word const&) at ??:?
#5  Foam::blockMesh::blockMesh(Foam::IOdictionary const&, Foam::word const&) at ??:?
#6  Foam::vtkPV3blockMesh::updateFoamMesh() at ??:?
#7  Foam::vtkPV3blockMesh::updateInfo() at ??:?
#8  Foam::vtkPV3blockMesh::vtkPV3blockMesh(char const*, vtkPV3blockMeshReader*) at ??:?
#9  vtkPV3blockMeshReader::RequestInformation(vtkInformation*, vtkInformationVector**, vtkInformationVector*) at ??:?
#10  vtkExecutive::CallAlgorithm(vtkInformation*, int, vtkInformationVector**, vtkInformationVector*) in "/opt/OpenFOAM/ThirdParty-2.2.x/platforms/linux64Gcc/paraview-3.12.0/lib/paraview-3.12/libvtkFiltering.so.pv3.12"
#11  vtkStreamingDemandDrivenPipeline::ExecuteInformation(vtkInformation*, vtkInformationVector**, vtkInformationVector*) in "/opt/OpenFOAM/ThirdParty-2.2.x/platforms/linux64Gcc/paraview-3.12.0/lib/paraview-3.12/libvtkFiltering.so.pv3.12"
#12  vtkDemandDrivenPipeline::ProcessRequest(vtkInformation*, vtkInformationVector**, vtkInformationVector*) in "/opt/OpenFOAM/ThirdParty-2.2.x/platforms/linux64Gcc/paraview-3.12.0/lib/paraview-3.12/libvtkFiltering.so.pv3.12"
#13  vtkStreamingDemandDrivenPipeline::ProcessRequest(vtkInformation*, vtkInformationVector**, vtkInformationVector*) in "/opt/OpenFOAM/ThirdParty-2.2.x/platforms/linux64Gcc/paraview-3.12.0/lib/paraview-3.12/libvtkFiltering.so.pv3.12"
#14  vtkSISourceProxy::UpdatePipelineInformation() at ??:?
#15  vtkSISourceProxyCommand(vtkClientServerInterpreter*, vtkObjectBase*, char const*, vtkClientServerStream const&, vtkClientServerStream&) at ??:?
#16  vtkClientServerInterpreter::ProcessCommandInvoke(vtkClientServerStream const&, int) at ??:?
#17  vtkClientServerInterpreter::ProcessOneMessage(vtkClientServerStream const&, int) at ??:?
#18  vtkClientServerInterpreter::ProcessStream(vtkClientServerStream const&) at ??:?
#19  vtkPVSessionCore::ExecuteStreamInternal(vtkClientServerStream const&, bool) at ??:?
#20  vtkPVSessionCore::ExecuteStream(unsigned int, vtkClientServerStream const&, bool) at ??:?
#21  vtkPVSessionBase::ExecuteStream(unsigned int, vtkClientServerStream const&, bool) at ??:?
#22  vtkSMProxy::ExecuteStream(vtkClientServerStream const&, bool, unsigned int) at ??:?
#23  vtkSMSourceProxy::UpdatePipelineInformation() at ??:?
#24  pqPipelineSource::setDefaultPropertyValues() at ??:?
#25  pqObjectBuilder::createReader(QString const&, QString const&, QStringList const&, pqServer*) at ??:?
#26  pqLoadDataReaction::LoadFile(QStringList const&, pqServer*, QPair<QString, QString> const&) at ??:?
#27  pqLoadDataReaction::loadData(QList<QStringList> const&) at ??:?
#28  pqLoadDataReaction::loadData(QStringList const&) at ??:?
#29  pqCommandLineOptionsBehavior::processCommandLineOptions() at ??:?
#30  QMetaObject::activate(QObject*, QMetaObject const*, int, void**) in "/usr/lib/libQtCore.so.4"
#31   in "/usr/lib/libQtCore.so.4"
#32  QObject::event(QEvent*) in "/usr/lib/libQtCore.so.4"
#33  QApplicationPrivate::notify_helper(QObject*, QEvent*) in "/usr/lib/libQtGui.so.4"
#34  QApplication::notify(QObject*, QEvent*) in "/usr/lib/libQtGui.so.4"
#35  QCoreApplication::notifyInternal(QObject*, QEvent*) in "/usr/lib/libQtCore.so.4"
#36   in "/usr/lib/libQtCore.so.4"
#37   in "/usr/lib/libQtCore.so.4"
#38  g_main_context_dispatch in "/usr/lib/libglib-2.0.so.0"
#39   in "/usr/lib/libglib-2.0.so.0"
#40  g_main_context_iteration in "/usr/lib/libglib-2.0.so.0"
#41  QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) in "/usr/lib/libQtCore.so.4"
#42   in "/usr/lib/libQtGui.so.4"
#43  QCoreApplication::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) in "/usr/lib/libQtCore.so.4"
#44  pqparaviewInitializer::Initialize(int, char**) at ??:?
#45  main at ??:?
#46  __libc_start_main in "/usr/lib/libc.so.6"
#47
 at ??:?
This is my blockMeshDict file :
FoamFile
	version	2.0;
	format	ascii;
	class	dictionary;
	object	blockMeshDict;
converToMeters 0.001;
vertices
	(0 0 0)
	(0 0 1)
	(0 0 2)
	(0 0 3)
	(1 0 0)
	(1 0 1)
	(1 0 2)
	(1 0 3)
	(2 0 0)
	(2 0 1)
	(2 0 2)
	(2 0 3)
	(3 0 0)
	(3 0 1)
	(3 0 2)
	(3 0 3)
	(0 1 0)
	(0 1 1)
	(0 1 2)
	(0 1 3)
	(1 1 0)
	(1 1 1)
	(1 1 2)
	(1 1 3)
	(2 1 0)
	(2 1 1)
	(2 1 2)
	(2 1 3)
	(3 1 0)
	(3 1 1)
	(3 1 2)
	(3 1 3)
	(0 2 0)
	(0 2 1)
	(0 2 2)
	(0 2 3)
	(1 2 0)
	(1 2 1)
	(1 2 2)
	(1 2 3)
	(2 2 0)
	(2 2 1)
	(2 2 2)
	(2 2 3)
	(3 2 0)
	(3 2 1)
	(3 2 2)
	(3 2 3)
	(0 3 0)
	(0 3 1)
	(0 3 2)
	(0 3 3)
	(1 3 0)
	(1 3 1)
	(1 3 2)
	(1 3 3)
	(2 3 0)
	(2 3 1)
	(2 3 2)
	(2 3 3)
	(3 3 0)
	(3 3 1)
	(3 3 2)
	(3 3 3)
blocks
	hex (0 4 20 16 1 5 21 17) new (3 3 3) simpleGrading (1 1 1)
	hex (4 8 24 20 5 9 25 21) new (3 3 3) simpleGrading (1 1 1)
	hex (8 12 28 24 9 13 29 25) new (3 3 3) simpleGrading (1 1 1)
	hex (1 5 21 17 2 6 22 18) new (3 3 3) simpleGrading (1 1 1)
	hex (5 9 25 21 6 10 26 22) new (3 3 3) simpleGrading (1 1 1)
	hex (9 13 29 25 10 14 30 26) new (3 3 3) simpleGrading (1 1 1)
	hex (2 6 22 18 3 7 23 19) new (3 3 3) simpleGrading (1 1 1)
	hex (6 10 26 22 7 11 27 23) new (3 3 3) simpleGrading (1 1 1)
	hex (10 14 30 26 11 15 31 27) new (3 3 3) simpleGrading (1 1 1)
	hex (16 20 36 32 17 21 37 33) new (3 3 3) simpleGrading (1 1 1)
	hex (20 24 40 36 21 25 41 37) new (3 3 3) simpleGrading (1 1 1)
	hex (24 28 44 40 25 29 45 41) new (3 3 3) simpleGrading (1 1 1)
	hex (17 21 37 33 18 22 38 34) new (3 3 3) simpleGrading (1 1 1)
	hex (21 25 41 37 22 26 42 38) neew (3 3 3) simpleGrading (1 1 1)
	hex (25 29 45 41 26 30 46 42) new (3 3 3) simpleGrading (1 1 1)
	hex (18 22 38 34 19 23 39 35) new (3 3 3) simpleGrading (1 1 1)
	hex (22 26 42 38 23 27 43 39) new (3 3 3) simpleGrading (1 1 1)
	hex (26 30 46 42 27 31 47 43) new (3 3 3) simpleGrading (1 1 1)
	hex (32 36 52 48 33 37 53 49) new (3 3 3) simpleGrading (1 1 1)
	hex (36 40 56 52 37 41 57 53) new (3 3 3) simpleGrading (1 1 1)
	hex (40 44 60 56 41 45 61 57) new (3 3 3) simpleGrading (1 1 1)
	hex (33 37 53 49 34 38 54 50) new (3 3 3) simpleGrading (1 1 1)
	hex (37 41 57 53 38 42 58 54) new (3 3 3) simpleGrading (1 1 1)
	hex (41 45 61 57 42 46 62 58) new (3 3 3) simpleGrading (1 1 1)
	hex (34 38 54 50 35 39 55 51) new (3 3 3) simpleGrading (1 1 1)
	hex (38 42 58 54 39 43 59 55) new (3 3 3) simpleGrading (1 1 1)
	hex (42 46 62 58 43 47 63 59) new (3 3 3) simpleGrading (1 1 1)
boundary
	plate
		type wall;
		faces
		(21 25 41 37)
		(22 26 42 38)
		(22 26 25 21)
		(38 42 41 37)
		(21 22 38 37)
		(26 25 41 42)
mergePatchPairs
The error says that face is connected to other face. I am using OF-2.2.2 and paraview-3.12.
seav is offline   Reply With Quote
Old   May 7, 2014, 16:15
Artur's Avatar
Artur
Artur will become famous soon enough
I don't think it's possible to create internal patch definitions using blockMesh directly. I'd suggest creating your topology first and then using topoSet to create a faceZone which then may be conveniently converted to an internal patch using createPatches. Have a look at the propeller tutorial in $FOAM_TUTORIALS/incompressible/pimpleDyMFoam/ to see some examples.
Peace,
A
Artur is offline   Reply With Quote
Old   May 8, 2014, 16:10
Thank You for your time. I have already solved issue, just didnt mentioned here
Cheers
seav
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 05:50
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 13:06
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
[Commercial meshers] Converting meshes that includes interfaces ham OpenFOAM Meshing & Mesh Conversion 29 January 8, 2007 08:58
