[snappyHexMesh] How to change patch types in snappyHexMesh?
Like Tree5Likes
  • 5 Post By Endel
Old   September 25, 2013, 23:15
Default How to change patch types in snappyHexMesh?
Vishal
inf.vish is on a distinguished road
Hi all,
I am meshing using snappyHexMesh for the first time.
I have a *.stl file wherein i have defined 3 solids - wall, inlet, outlet (those are the names given to the solids)
when running snappyHexMesh this is part of the output
Adding patches for surface regions
Patch Type Region
xyz:
6 wall xyz_wall
7 wall xyz_inlet
8 wall xyz_outlet
Added patches in = 0.02 s
As you can see it has defined all the three boundaris as "wall" but inlet and outlet (of a pipe for example) are always defined as "patch". So how do i change the patch type of "inlet" and "outlet"?
Do i need to change only the boundary file in constant/polymesh? Or is there any other way to define it using snappyHexMesh - I saw something called as "patchInfo" in SHM but not sure how to use it to define different patch types to different boundaries.
inf.vish is offline   Reply With Quote
Old   May 26, 2014, 07:25
Endel is on a distinguished road
I just stumbled upon this post and think I know the answer, if it is still needed.
If you refer to https://github.com/OpenFOAM/OpenFOAM...ppyHexMeshDict you can see, that there is a patchInfo entry in "refinementsurfaces". If you don't set the patchInfo entry, SHM will refer to any given .stl-patch as "wall" by default.
So all you need to do is give it the patchInfo like this:
// Surface based refinement
    refinementSurfaces
        yourStl.stl
            // Surface-wise min and max refinement level
            level (2 2);
            // Optional specification of patch type (default is wall). No
            // constraint types (cyclic, symmetry) etc. are allowed.
            patchInfo
                type patch;
Hope that helps,
cheers!
Endel is offline   Reply With Quote
steadyUniversalMRFFoam Tutorial fails in MixingPlane HenrikJohansson OpenFOAM Bugs 0 February 14, 2019 04:48
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 09:28
chtMultiRegionFoam Tutorial m.nichols19 OpenFOAM 12 September 9, 2010 11:56
CheckMeshbs errors ivanyao OpenFOAM Running, Solving & CFD 2 March 11, 2009 02:34
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
