[Other] Mesh from OF23x to OF3.1ext. Error of format |
March 11, 2015, 12:25 |
M. Montero
Rep Power: 17 |
Hi all,
Using the same mesh made with snappy into OF23X, I get an error when using checkMesh into OF3.1-ext. --> FOAM FATAL IO ERROR: unexpected class name faceCompactList expected faceList while reading object faces I have changed faceCompactList to faceList and a different error happens: --> FOAM FATAL IO ERROR: incorrect first token, expected <int> or '(', found on line 20 an error When trying to launch snappy directly on OF3.1-ext I get a segmentation fault error with no more information about why. I would like to try pimpleDyMFoam implementation on OF3.1 ext. Thank you |
March 18, 2015, 04:03 |
W.T
Rep Power: 13 |
I have similar problem when I try to change version of OF and mesh is written in binary format. When files are written in ascii format everything is ok.
January 16, 2017, 02:39 |
Vaze
Rep Power: 17 |
I have similar problem. I saved file in ascii format but problem persists. Do you have any other option to work on?
Thank you Mvee |
January 16, 2017, 05:13 |
W.T
Rep Power: 13 |
Hi
There is a tool "compactFaceToFace" wich converts constant/polyMesh/faces file from compactList (default in OpenFOAM) to standard list (foam-extended). Tool can be found here: https://www.cfd-online.com/Forums/op...mpactlist.html |
[Commercial meshers] ICEM mesh file in correct format for OpenFOAM | SamEngD | OpenFOAM Meshing & Mesh Conversion | 0 | April 5, 2017 06:29 |
[snappyHexMesh] Snappyhex mesh: poor inlet mesh | Swagga5aur | OpenFOAM Meshing & Mesh Conversion | 1 | December 3, 2016 16:59 |
Star CCM Overset Mesh Error (Rotating Turbine) | thezack | Siemens | 7 | October 12, 2016 11:14 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
Mesh motion with Translation & Rotation | Doginal | CFX | 2 | January 12, 2014 06:21 |
