[snappyHexMesh] Problem with non-manifold surface
Old   June 22, 2014, 15:20
Default Problem with non-manifold surface
LeonardoCampos
LeonardoCampos is on a distinguished road
Hi, I an new to openFoam and I am having some trouble running the snappymesh. When I use the surfaceFeatureExtract it wrote that it was a non-manifold surface, so I tried using a simple 1x1x1 cube instead and the same was written. I certified that the surfaceFeatureExtractdict was right and I could open normally both structures in parafoam.
I used SolidWorks to generate the .stl files.
Does anyone have any idea of what my problem could be?
Thank you.
LeonardoCampos is offline   Reply With Quote
non-manifold, non-manifold surface, surfacefeatureextract
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
free surface problem with capillary effect rabbitmelon CFX 25 August 16, 2013 03:05
Catalyst Modelling Boundary Problem (Surface reaction) Fritz STAR-CCM+ 0 August 6, 2013 09:10
surface orentation problem in icemcfd jeevan kumar CFX 0 August 18, 2008 04:25
Surface orentation problem in icemcfd jeevan kumar CFX 0 August 13, 2008 01:54
